New nut and set up, in this heat?
robgilmorobgilmo Frets: 3664
:) Is it a good idea guys? It's quite hot and humid here.
  • ICBMICBM Frets: 72825
    The only possible issue is that you may have to readjust the truss rod once the weather returns to normal.
  • robgilmorobgilmo Frets: 3664
    Is that even ever going to happen? Tired of this heat now.
  • ColsCols Frets: 7200
    We had rain yesterday.  Real honest-to-god rain, falling from the sky and everything.
    I've even been sweating in the shower!
  • prlgmnrprlgmnr Frets: 3998
    With my reputation?
  • teradaterada Frets: 5114
    prlgmnr said:
    With my reputation?
    I would have thought this was the last place the 13th Duke of Wybourne would be  :s
    Fnarr
  • AlnicoAlnico Frets: 4616
    Audrey's Telecaster has needed adjusting twice since last week.
    I tend to check the relief on each of our guitars every time I play now since the tools are only 3ft away and it only takes 2 minutes to adjust a truss rod but yeah, the whole heat vs neck thing does get on my nerves a bit.
    I just checked my relief and its 0.5 mm, it was 0.25, so heat = more relief?
    Obeche will do that - that neck pocket won’t be rock solid
    Usually. The truss rod expands more than the neck, so it gets looser and the relief increases. But high humidity makes the neck expand as well, so it’s not totally predictable...
    I didn't know that,
    Thanks.
    I didn't know that,
    Thanks.
    It's quite easy to dent and mark, and I would expect it will give a bit in the humidity as well.
    I didn't know that,
    Thanks.
    Yeah it makes sense it just hadn't occurred to me until you said it.
    We'll that didn't happen, still waiting on my bits, has anyone ordered from strings direct? They are usually quite quick when I order from them, on the upside its cooled right down here and has been raining all day.
