Matchless Independance
  • andy1839andy1839 Frets: 2197
    ICBM said:
    57Deluxe said:
    actually, matchless impedance = BOOM!
    lol
    I see what you did there :).
    Clever, but no... ;)
    It's usually much less critical than popular wisdom will have you believe. There are a few exceptions, but generally any valve amp will take a half to double impedance mismatch with no trouble at all, and often 4:1 is OK. It's also always OK if the amp isn't cranked.
    But it's still not a good idea to use a severe mismatch (eg amp at 4 ohms, 16-ohm cab) to try to reduce the volume of an overdriven amp, that *can* cause damage.
    Sorry to be dull, too good an opportunity to miss :D.
    So if I was wanting to use an 8 Ohm and 16 Ohm cabs at the same time is it possible?
  • ICBMICBM Frets: 72599
    Yes. The combined impedance (in parallel, which is the normal way) is 5.33 ohms, which is safe with the amp set to either 4 ohms or 8 ohms. 2/3 of the power goes to the 8-ohm cab.
    Brill, cheers!
