For Sale / For Trade Gibson ES335 63 re issue with Monty's PAF's £2500
For sale is my 2016 ES335 63 re issue in cherry red.
It has been equipped with a set of Monty's PAF's ( I no longer have the old MHS humbuckers that were in it ) and I've also swapped the kluson tuners for a set of Grovers for better tuning stability. I do have the old klusons still if you want to swap them back although I believe some reaming took place to fit the Grovers but the old screw holes are still there. The pick ups were actually fitted by Matt of Monty's pick ups and at the same time he put some russian caps in.
It is currently set up with a set of flatwound 10's but can be swapped back to normal 10's and I don't think any adjustment would need to be made.
Although it's been gigged there are no dings or buckle rash on the guitar and it plays beautifully with a low action.
Block inlays on a rosewood board with a 12" radius... neck is typical for a 63 re issue.
One of the tone controls does have a chip out of it by the silver insert but these are readily available if it bothers you.
I have the COA and original case with the yellow lining which is in perfect condition as I used an SKB hard case to take it to gigs which I will also include in the sale.
I am selling this as I recently took delivery of a gold top tele ( there's a NGD thread about it somewhere ) and it's all I have been using since I got it and I'm not one for having guitars hanging around not being used and it's a real shame this is not being gigged.
I am based in Bedfordshire and I won't post this. Trade wise ...try me..
£2500 gets it.
Here's a couple of pictures and I can provide more via whatsapp for anyone who is genuinely interested.
cheers
https://imgur.com/a/BlvjEI thought for that money 2 pictures was rather lazy so here's some more...
- “To play a wrong note is insignificant; to play without passion is inexcusable.”
