Headstock Decals.
  • SteveRobinsonSteveRobinson Frets: 7085
    I've applied transfers from guitar decals.co.uk over Tru-Oil. A smear of 50:50 PVA glue first holds them firm.
  • WezVWezV Frets: 16807
    Jalapeno said:
    Gagaryn said:
    Can you true oil over these without any issue?
    R&F recommend lacquer and say not to apply to an oiled surface so I presume oiling over would be a bad idea.
    Probably make them move/shrink/crinkle
    They go on fine, they just don’t stay on.
    Probably could be oiled over, but you would need to spray the oil over it in light coats so it doesn’t move.
    which is why steve’s suggestion would be the way to go
  • Thanks for the help guys, I've ordered from Guitardecals.
