The reason Chellos are allowed in the cabin is they can be secured with a seatbelt, a guitar cannot (according to airlines). You need to buy a seat though.
Feedback
Get to gate early with guitar and ask them if you can get space in captains closet for the guitar case. Being nice and polite is the key here.
If they say no you can check the case at the gate. At worse this means they put it in hold....at best they are too busy and don’t have time so just sort you out by putting in cupboard or similar.
Worth a go but the shitter the airline the less likely you will get a good result.
oh ... flying with a guitar in your luggage ... got you ...
Getting more paranoid as time goes on as its not a Hiscox, although depending on the weight of the other luggage I have, I may just take the guitar apart and stick it in my suitcase for safety. Empty case in the hold won't bother me at all. Worst case scenario though and it goes in its case into the hold, surely this case should be okay?
The yard is nothing but a fence, the sun just hurts my eyes...
i first off paid the 50 and put it in outsized in a hard case. All was fine.
for Strats I have also taken neck off and thrown it in the case in middle of clothes and had no problems.
now I tend to pay the upgrade seat charge get Speedy boarding make sure I am at the gate and speedy boarding que sharp and take it as my extra bit of hand luggage and put it in the overhead. I have done this with the Private Stock, Valley arts Tele and Taylor gs mini, oh and Greco les Paul which are all compact fitted cases.
Never had a peep or problem from the gate people or cabin crew.
had one obvious regular flyer who kicked off as she tried to put her over stuffed roll on into the overhead and complained to cabin crew that there was a guitar taking all the space and the stewardess said not a problem Madam we can put that in the hold as the gentleman has paid for speedy boarding and gets an extra bag.
I would just pop the neck off and put it in my main case.
I'm happy to take a Tele or Strat in a Hiscox through the baggage system, since I figure that's about the most indestructible guitar & case combination possible. And wrapped in that industrial cling film stuff to stop baggage guys trying to open anything...
I've got Gibsons in standard TKL type hardcases in the cabin with me a couple of times. To do that I ask nicely at check-in to gate check it. They never have a reason to say no, but you can lay it on with a little "it's very fragile so while I'm happy for it to go in the hold I need to make sure it doesn't go through the conveyor belt system".
Then when you get to the gate, say nothing unless challenged, and when you get to the plane, either put it straight into an overhead (if you're on a plane with big enough bins) or ask very nicely for them to put it in a cupboard (again because v fragile & sentimental value etc etc). They key with all this is to be as friendly and polite and accommodating as possible at every stage, while being firm enough to make sure it doesn't ever see a conveyor belt.
What also helps here is I have a lot of loyalty with various airlines, so get priority boarding, which makes all of this much easier. And platinum status with Etihad means they're happy to do whatever to help.
That all being said, with a budget airline, I would want it in a Hiscox, or in 2 pieces inside my suitcase. I wouldn't risk the gigbag/cabin thing because they're notoriously much less inclined to do nice things to keep customers happy, and you're fucked if they insist on checking it in, in a gig bag.
Feedback
Feedback
https://www.ebay.co.uk/itm/BLOODSTONE-Neck-Bolt-Anchor-Kit-Guitar-Tone-Upgrade-Kit/162926902884?hash=item25ef333e64:m:mK4BmLDfngffhr6GxtGqfHA
