Cable type hardly matters so long as it is rugged and easy to work with. I would avoid anything with the greasy ***t "anti-microphonic coating.
Tips for the pancake jacks. Scrape/file off the bright plating at the solder points, it makes them much easier to solder. If they use those tiny screws, use a dab of 'er nail varnish on the threads or heat shrink. Better both!
Dave.
