New Schaller strap lock design
  • ICBMICBM Frets: 72610
    TINMAN82 said:
    With the matchstick method, the screw is being jammed in with matchsticks and glue (like you’d jam a nail in). It may be secure but it’s not running in a thread, particularly if it’s jammed in when the glue is wet as was suggested.
    Yes it is. You don't "jam" it in, you screw it in exactly as normal. It forms the thread by compressing the new wood.
  • TINMAN82TINMAN82 Frets: 1846
    You could be right. But my assumption is that the screw cannot then be loosened (backed out) and tightened repeatedly as you could with the original thread in wood. If the thread is too fragile for that then it may work loose. My assumption is that the screw is acting more like a barbed nail. I’ve never tested this and if you guys have and it’s worked for decades then you’ve proven me wrong, which is great!
  • BrizeBrize Frets: 5635
    Those new locks look horrible - are Schaller completely discontinuing the old type?
    Based on experience so far I hope not. The fingerwheel is a definite improvement over nut and washer though.
  • Another +1 for the new S-locks, the small set screw to stop the wheel loosening is a big improvement over the old method where the nut would loosen (unless fixed in place with a bit of superglue).  Not changed over the buttons as no need yet.
