I'm building a strat FINISHED! (well, not quite ...)
  • duotoneduotone Frets: 995
    Credit for doing this on small portable workbenches!...been there and done that when doing DIY at home.
  • enjoenjo Frets: 278
    Awesome, even down to the clay markers!
    Please keep sharing - I'd love to do this one day. Do you mind sharing where you sourced the wood from?
  • Lovely work. Do you do commissions or purely for yourself? I ask as coincidently I'm after a strat neck with rosewood and clay dots.
  • SaszSasz Frets: 10
    It looks great - thanks for taking the time to document it all!
  • axisusaxisus Frets: 28347
    This time I think I got the wood from http://www.exotichardwoodsukltd.com/ I don't always remember as I tend to get it some time in advance of making a guitar
    I'm strictly amateur, I don't consider my guitars to be selling quality! There are others here who make guitars to a higher standard.
    Body sprayed Sonic blue and aged
    Shielding done
    Start of neck carve. Usually a combination of worrying and very satisfying. Terrible pic unfortunately!
    Basic neck shaping done
    levelling and rounding off frets
    Frets polished
  • That is absolutely beautiful...! And very exciting to watch...
  • Wow amazing work! Good choice going with sonic blue !
  • MLten80MLten80 Frets: 162
    excellent work!! just got myself some strat templates so very inspiring :)
    where did u get your truss rod? is it single or double way?
    thanks
  • paulnb57paulnb57 Frets: 3073
    Pukka job!
    2 way. I think it was from Warman, bought a couple rather a long time ago so the memory is a bit hazy. I have certainly had at least one from Warman in the past.
  • munckeemunckee Frets: 12422
    axisus said:
    planning placement of trem screw holes.
    Mock up of guitar so far.
    plastic and metal parts aged a bit. Doesn't show that well in this pic.
    Love the pickguard, are you able to divulge your ageing secrets?
    When this said 'building' a strat I didn't realise you were creating from scratch!
    No secrets with me. I read somewhere that you can get an interesting aged look on a pickguard by spraying it with tinted nitro varnish. I did that then rubbed it all over with fine wire wool, wearing some bits back more than others. Added some mock rust wear around screw holes with some enamel paint.
  • Simon_MSimon_M Frets: 542
    This is really good @axisus ! I wish I had the confidence to have a crack at something like this. I've always fancied making a LP Junior but neck building worries me!
    OK so the whole thing is together and playable! It still needs rather a lot of sorting to get playability up - nut slots, some fret levelling, truss rod adjustment etc. but basically I am loving it already. New no 1!
    That looks great!
    What did you use to yellow the blue?
    enjo said:
    That looks great!
    Tinted varnish from Manchester guitar tech
