Shuker Uberhorn Fretless 4 Part Deux
BridgehouseBridgehouse Frets: 24579
A little while back, you may recall, I became the rather proud owner of a Shuker Uberhorn Fretless 4 (Serial 001)
Well, its a superb bass. It's build quality is exquisite, it looks utterly incredible, and it plays like no bass I've ever played before (even with my hamfisted attempts at fretless I know it's something special). Here it is on arrival:
IURPExRjpg
Well (and it's a bit of a Jackanory this, so get a comfy chair and a coffee..) I was never really happy with the electrics side of things.
Firstly, the under-board mag Jazz pickup was single coil, and noisy - so that got swapped out for a Nordstrand.
Then, I noticed that it was running an EMG gain boost which was as noisy as anything, and ripped that out.
Then, things went properly south. An odd noise developed from the piezo preamp, which eventually became a not so odd noise, and eventually no noise at all.
Investigation revealed two things - the ghost acoustiphonic preamp had died, and the summing board for the ghost piezo saddles had effectively eaten itself. I tried many a re-solder and extra bit of dabbling before ripping the whole lot out in a fit of Uber-rage. It was just mightily frustrating that I had a bass which looked amazing, played so damn well, but was completely let down by an electronics package that wasn't doing it justice, and if I'm honest, was past it's best at 10 years old.
Now, to be fair to Jon, it was top drawer stuff when built, and it's lasted really well. However, my big problem and frustration was finding a suitable replacement - the options were limited at best, and in reality pretty much nowt at all. Number one option was looking like a new ghost board and replacement preamp. Ugh. I'll be honest - I don't like the ghost board. It requires you plug any mag pickups into it and forces you to separate it all out. It's messy and it just isn't very logical. @ICBM will attest to the sheer levels of frustration - and he's right - mix and match complicated electronics are a bitch.
After some ruminating, kicking chairs and generally feeling rather miserable about the whole thing, in a fit of last ditch desperation I emailed John East and simply said "Can you do anything that might get this up and running again?" (https://www.east-uk.com)
Of course he could. In fact, he said there were options aplenty and I can pretty much have what I want. Sounded spendy - but it really wasn't.
John East is a legend of a man. Apart from being a genius, he is polite, enthusiastic and utterly pleasurable to deal with. I'll say it now in case I forget - if you are thinking of upgrading any electronics, go to him first. He will sort you out. His kit is absolutely the best and it's just so easy to install.
Anyway, we discussed options and I came up with my preferred configuration. John spent a bit of time ruminating, then came back with a "yep - all possible". So he built it, I paid for it, and he shipped it. It came this morning:
hAFdeCzjpg
I decided to ditch the frankly terrible ghost summing board and soldered them all together to two wires - a hot and a ground. That gave me this:
3EfjtPQjpg
John's stuff is just so neat and easy to install. Given how much gubbins there is in this bass now (like about twice the amount there was) it's a miraculously tidy install (and just for @ICBM's benefit - it's one system from one manufacturer *bliss*):
UpGYbR0jpg
And now I have a bunch of new knobs and a lot more stacked ones than before!
lYSCN5Jjpg
So what configuration did I go for? Well..
- The Piezo goes into John's own Piezo Preamp/Mixer which allows you to set gain and sets the right impedance etc, as well as allowing you to have a piezo treble roll off to get rid of any quack. Nice.
- The output from this goes into the Uni Pre 4 - the Mag pickup and Piezo output go into the volume board and allow volume, blend, individual balancing gain for each pickup, and a bunch of other tuning options
- There rest is a standard Uni Pre 4 except for the passive tone, which is also now a piezo treble roll off when active, and I have a mute switch added.
So the knobs are now:
1. Volume/Blend
2. Passive Tone/Active Piezo Treble Roll Off
3. Mid/Mid Freq Sweep
4. Treble/Bass
and the two switches are:
1. Active/Passive
2. Mute
The real difference (apart from the quality) is the fact that both piezo and mag feed into John's preamp so no matter what the blend I can get the most out of the piezo and set mids, treble, bass, treble roll off etc. as well as have full control over the mag just the same. I also get a passive mode which means I can use it passively and run a booster pedal on a board for more oomph.
The Nordstrand sounds like it should now. The Piezo is just so different - far more full spectrum and far far more tonal possibility - from clanky spiky almost acoustic to a proper dull thumpy double bass sound. The Nordstrand gets me mids till my eyes bleed as well as that traditional Jazz type of sound. Blend them together and it's like a Jazz with a whopping great low down thump from a double bass all in one.
It now actually sounds like it looks. It sounds like it plays. It sounds flipping great and though I thought it sounded really rather good before despite the niggles, I had no idea it would open out like this.
  • ICBMICBM Frets: 72345
    Very neat, considering the amount of crap circuitry there is in there . It also seems well-thought-out from a usability point of view - the two don't always go together, in either direction!
    Does the passive mode still let you use the piezo, or just the magnetic? I assume the latter, but having a dead-battery backup of any kind with a system that complex is a bonus.
    I also wasn't expecting the Jazz pickup to be that close to the bridge! I thought it would be in the middle of that back plate. You've done a very thorough job of the shielding too...
    The passive mode gives me both, but obviously quieter... the blend control is passive so I can still blend them too...
    I decided to shield the shit out of it ;)
    edited October 2018
    Oh, and I suspect the mag placement was partly body thickness related and partly to get more clanky mids out of it...
    Oh, and @Andyjr1515 - this is the “final solution” for the ghost crap ;)
    Hmmm... I'm now struggling to think of reasons I should still hate it :).
    Seriously, that does sound like an exceptionally thoroughly well-thought-out system.
    It's the little details that make it - individual gain trim pots for each pickup on the volume board, solder less screw in pickup connectors, jumpers to let you change the functions of the pots, built in attenuator switches to turn off bits of the mixer to stop unwanted additional noise.. that sort of stuff.
    Oh, and the face he's a thoroughly nice bloke who chats everything through and builds exactly what you need, and nothing you don't need. It's also the first time I've had a mute switch on a bass and I can see it being bloody useful!
    So can I... an easy solution to fretless bass solos if anyone else can reach it quickly!
    edited October 2018
    Next you'll be telling me I should send it away to get it fretted
    I'm not a bass solo kind of guy.. as anyone will testify who was at the Hudders Jam and stood in anticipation waiting for the bass solo in All Right Now for 25 seconds whilst I enjoyed the silence and wondered why everyone was looking at me...
  • FunkfingersFunkfingers Frets: 14428
    Learn some Primus, you damned blue collar tweaker.
  • TTonyTTony Frets: 27507
    UpGYbR0jpg
    That's got to be worth a wow of anyone's money.  That's some very neat (and complex!) wiring.  Nice work Mr BH.
    Nah. I’m all about de riddum
    TTony said:
    UpGYbR0jpg
    Why thank you sir, but I do have to say, Mr East’s preamps do make it very easy...
