Line 6 Helix
1319320322324325426
  • NorthernStompsNorthernStomps Frets: 398
    I’ve never really looked into the helix much. Can it genuinely go toe to toe with Axe Fx and Kemper?
    Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
    Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
    Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
  • Most people think so. Some people deeply involved in the ‘church of Cliff’ may disagree.
    Pete Thorn has a full fat helix as his back up. He knows tone and can use any gear he wishes financially.
  • I’ve never really looked into the helix much. Can it genuinely go toe to toe with Axe Fx and Kemper?
    Tone-wise, I believe so. As with all modellers and digital gear, it depends whether you want 100% fidelity in tone-chasing, or whether you just want to make great sounds. Each of the big modellers has its own idiosyncrasies in terms of tone; for example, I don't really like overall sound of Fractal gear. I don't know why, I just don't. Kemper's a special case in that when you've got a good profile, it naturally sounds noticeably more "real" than the others.
    Focusing on tone alone, though, is where I think a lot of folk go wrong with modellers. The reality is that, in a band mix and assuming equal skill and effort put into setting a patch up, nobody on the other side of the room would really be able to tell which of the big three (or maybe even four) is being used. It's really about usability for me, and the ergonomics of actually using the unit in a live context; that's where the units really differentiate themselves.
    For my purposes, the Helix snapshots fix all of the complaints that I had about other modellers on the market, and that's enough for me.
    <space for hire>
  • robinbowesrobinbowes Frets: 3049
    I've not compared my Helix to anything else directly - I don't think such comparisons are relevant.
    My criteria are:
    • Does it sound good enough?
    • Is it easy to use?
    • Is it more convenient than an amp/cab/pedalboard?
    The answer to all three questions is "yes", so the Helix stays :)
    R.
  • I think it has got to the point now where quality wise they are pretty much on par. It comes down to miniscule tone differences that some people prefer over the other.
    For example if you had several JCM800's side by side there would be subtle differences between them. Different people would prefer one amp over the others. Digital modelling now in the higher end units is like that for me.
    I for one love the Helix, firstly I love the sound and secondly the User Interface is second to none in it's ease of use.
  • shuikitshuikit Frets: 224
    siremoon said:
    Jumping into this in prep for buying the stomp probably but can helix do a decent transpose for drop tunings? What patch does this well?
    No is the short answer at the moment.  It has a pitch shifter block which is sort of just about ok-ish for single notes but truly awful with chords.  However the hints and rumours are that something vastly superior is in the works for a future release as Line 6 hired some pitch shifting gurus a while back.
    Sounds like they're working on it https://www.thegearpage.net/board/index.php?posts/27290357/
    I get a bit of stuck here for having all three but it does give me the opportunity to give an opinion based on using them side by side with enough time spent to work out the bugs of each one
    Axe Fx you can do a lot with it and the FX are good, the amp modelling itself I personally aren’t as convinced by as the Helix but it does do more ‘wacky shit’ It’s loud with a fan and the foot controller programming is a bit clunky.
    The Kemper does good amps depending on the profiles however it only does 1 at a time. The FX have come on leaps and bounds from the early days but some are passable at best. The foot controller is easy enough to program but sets and multiple patches/performances are a boot in the nuts to set up and manage
    also the whole thing is a bit of an arsehole to edit, especially under gig conditions.
    The Helix is the best overall compromise for me. The amp modelling can be great with the right tweaks. The FC are a good balance of what you need at a reasonable quality with some exceptional models. The flexibility and ease of use are unparalleled in my opinion so you can get more of what you want quicker.
    Easy to deal with in gig conditions and it’s the one I use live
    In fact so much so i don’t even take an amp any more
    i just don’t notice the difference on stage
    Thats just my opinion based around what suits me. Hope it’s of some use
    Nice one thanks, its good to hear from someone who has used all three rather than "well I hear that...."
    Basically i'm quite interested in the HX Stomp. If it has the same sound quality as the Helix, and the Helix is as good as you say then i'm sold!
    In that price bracket its a no brainer.
  • Jonathanthomas83Jonathanthomas83 Frets: 3472
    edited October 2018
    Absolutely this. I'm a very happy Kemper user, and would rate that as it better suits my needs for tones but the HX Stomp has even piqued my interest to compliment it.
  • Mr Igloo apparently said that the 6 blocks are because the amp modelling is going to take up a lot more DSP in the future. I’m assuming this will be in 3.0 sometimes next year. Not entirely sure how much better it can get!
  • sgosdensgosden Frets: 1994
    channel switching in one block?
    I don’t think they would keep the blocks down for that. There’s lots of one channel amps on there. Think it will be some new super HD special mojo diode code amp modelling they’re working on
  • siremoonsiremoon Frets: 1524
    He also said that the size of the screen they could fit onto the HX Stomp was a major factor and that 6 blocks was considered the most they could accommodate without compromising the reputation that the Helix range has established for its UI and ease of use .
    “He is like a man with a fork in a world of soup.” - Noel Gallagher
  • It was the night before Christmas...
    We usually get updates on Thursdays don’t we? Looking forward to seeing what they’ve been up to, not really bothering there’s no more models in this one.
  • JetfireJetfire Frets: 1696
    Im interested in what other part of the update will be...but I never found the tuner bad in the first place!
    Same here!
  • goldtopgoldtop Frets: 6176
    Does anyone else find the Helix's headphone output quiet? I'm having to put the Headphones dial at almost maximum to get decent level. These are AKG phones, with typical studio impedance of a couple of hundred Ohms, I think.
    It could be a gain-staging thing that I'm getting wrong, but I don't think so. Unless I've missed it, there's no way to monitor 'signal' levels in the signal path.
    Any advice?
  • TimmyOTimmyO Frets: 7523
    Any advice?
    Turn the dial to almost maximum
    Red ones are better.
    I find it pretty quiet with my sennheisers but with my iems it’s mad loud!
