http://stormriders.com/guitar/telecaster/guitar_wood.pdf
But bizarrely, the conclusion reached by the 'scientists' - confirming their own original hypothesis - is totally at odds with their own experimental data! Which is something of a perfect illustration of how much belief affects the result, I think.
If you look at the graphs, while the overall shapes of the curves are similar, there are differences at some frequencies in the order of 10dB - that's huge, and cannot be simply brushed aside as not being audible in the amplified signal.
But I would also take a bet that both guitars sounded like Telecasters.
That at least covers quantity and density, species is just a more subtle variation in density.
Gibsons designs are good examples.
You have the Les Paul, SG, Flying V, explorer and 335 all made with the same recipe, even the same woods .... but the structure of the body and neck is very different
Instagram
Play a les paul junior or special like a tele it will sound like a tele. both different woods, construction, pickups, scale length, pot values.
Player makes the most significant difference, everything else is just as inconsistent trivia.
And if this wasn't true, why do so many of us all disagree on what is and isn't tonewood as we cannot prove it in any way.
Nice tone Peter Buck gets out of that Rickenbacker...
... except that he recorded it with a Les Paul
In fact, if you listen very carefully to the last two chords, I think you *can* tell - they're very thick-sounding, something you don't really get from a Rick - but by and large, Buck makes anything sound like one.
https://physicae.ifi.unicamp.br/physicae/article/view/154
http://physicae.ifi.unicamp.br/index.php/physicae/article/view/physicae.9.5/116
Unless someone can provide links to other journal-published articles showing that the species of wood used to make the body of an electric guitar does have an effect on the timbre of the sound produced by an electromagnetic pickup than this is currently the best answer to the question we have. I do know that many believe otherwise, which is to be expected given the complexities of human psychology and perception. But then people believe lots of things that don't stand up to real scientific scrutiny, especially it seems when it comes to the ability to discriminate between subtle differences in sound - just look at the audiophiles for some good (and often directly comparable) examples!
Even if we accept that 'tone wood' does have some minor effect, the question remains whether any difference is actually perceptible, especially when an amp is being driven. I would suggest that a whole range of factors from the amp used, the pickups, variations in the values of the components in the guitar's wiring, the players technique, the plectrum used and so on have such a vastly greater effect on the sound produced that any difference caused by the species of the wood the body was made from would simply be drowned out.
if you spent thousands on a vintage Les Paul, you would be determined that it must be used as you spent so much on it.
Material will I think make a difference to sustain but not tone. No such thing as tone wood in my opinion only marketing hype. The quality builder will make you a good guitar out of any material as they are quality builders and know how to make a guitar work.
In the study you linked, there are also large differences in the graphs. It makes no difference what the written conclusion is, the evidence is right there.
What it proves even more conclusively than that the body wood *does* make a difference, is that people who want to deny it does - and who start from that assumption, in both cases - will ignore the evidence of their own tests. This is a classic example of confirmation bias.
If you can find any *other* study than the one you keep linking which does actually have data which supports the conclusion, feel free to post it...
Yes, definitely. There may be some broad generalisations related to density and hardness, but no more than that.
Particularly given that in some cases there can be some debate about what exact species of wood was actually used in some guitars - not least the mahogany in 50s Gibsons.
That's why people will claim something as a fact - on the basis that "fact" means something they completely believe themselves.
The test required to even get the first useful information about whether tonewood is a fact or not has either never been done or, if it has, no one I've seen arguing about tonewood knows about it to link to it.
