Hi
As my first post here gave me so much good advice and opinion I thought I'd try again with my second dilemma.
I'm starting to look at buying my first guitar upgrade. Now life has thrown me a few curve balls so it's further away than I thought it was a month ago but that's OK as there are some things that I need to figure out.
One of the things that I've come to understand is vitally important is to play what you are considering buying. Whatever it's technical specifications the feel of it coupled with the aesthetics are major factors which can only really be tested 'in the flesh'.
Now this is where I'm starting to struggle.
I have two local music shops.
One is very large and carries all sorts musical equipment and has a decent size guitar section. It tends to carry more stock aimed at the beginner than anything else and it's actually where I got my first Epi from. It doesn't have that much choice in intermediate or expensive guitars and also seems to be more focused on Fender/Ibanez than anything else. Nothing wrong with that but having had a look around there isn't really that much in there that makes me go 'wow' when I see it on the wall.
The other is a much smaller shop that seems to manage to exist locally by catering for the other end of the spectrum. They don't have a huge stock but what they do have all look very nice. They have more PRS than anything but we are talking the price end of the PRS range that I'll never be able to afford/justify. I think maybe because they cater for the more expensive end of the market and seem to be generally well thought of by the local gigging musicians they do have a large second hand section. This does at least mean that something I'm interested in might turn up there from time to time.
So how do people without a convenient local shop go about trying out guitars? Do you plan a day trip to somewhere where you know carries the sort of stock your interested in? Do you buy mail order and if so what happens when you open the box and despite having arrived in perfect condition that new guitar just isn't what you want when you get it?
For a secondary question how good do you need to be to actually play something in a shop that just doesn't make you look like a complete idiot? Despite wanting a better guitar I'm still very very new to all this so it's not like I can turn up and knock out a few covers or complicated solo's on anything! It's part of what scares me about going to the small shop with the second hand selection. I know it's a place that 'real' musicians frequent and I certainly don't belong in that category. That's not to say anything about the actual staff in there as I've never quite had the guts to go through the door. They may be great about it all I just don't know!
(Just don't play Seven Nation Army/Smoke on the Water/Stairway to Heaven, etc )
Whatever the case, make sure you go into that smaller shop & keep an eye on the second hand section like you mentioned!
I was very afraid of this being a 'fad' so I picked up an Epiphone SG special which I think coast me £130. I figured that if I gave up after a month then I would not have wasted too much money. For the price it's a fantastic little guitar and I probably don't need anything better. It holds it's tuning reasonably well, it's not got an awful action on it. It does however have some issues that are perfectly acceptable for such a cheap instrument. The mechanical parts like the tuners and the switches are ok but are certainly not going to last forever. The pickups are OK but in reality there isn't much difference no matter what configuration you select. I'm not knocking it as it's been great for me and as I said, in reality, I probably don't need anything better given my standard of playing. When I was looking at new guitars the wife actually said "but you can't play the one you got".
Now I'm 9 months down the line and whilst progress has not been rapid (I'm old) there has been enough that I'm going to plod along and just see how much I can learn. I've got a great tutor, reasonable expectations of my ability and I'm not going to be giving up. So I'm on the lookout for something that's a little more polished and can be 'my' guitar, perhaps forever. I've got a much better idea of what I'm after and I don't want to keep doing minor upgrades over the next few years. So I figured that if I were to be looking in perhaps the £500 ballpark, especially second hand, I could get something quite nice that will last me. Even if later down the line I start contemplating new pups or tuners or whatever I should at least have a body that it's worth doing those things to.
So I'm looking for something that I would say is not an 'entry level' guitar but I'm never going to be able to afford or justify the higher price instruments that I see in the classifieds here. I am however going to be spending enough that I don't want to just be taking a 'punt' on something from an online retailer as I want to at least make sure simple, non musical things, like the weight and the neck feel 'right' to me.
You may have a shape in mind that your guitar heroes play and you want, but do try others too.. a lot of my favourite artists for example have Les Pauls, but i just don't get on with them...
Also don't be swayed by brand and things.. as you have said you've only recently gotten serious about this, so you've probably got a fair idea of the major brands i.e. fender, gibson, PRS etc. But don't discount other makes too because you haven't heard of them.
Good luck!
I am a terrible guitar player, but I just play chords and odd riff, don't care if people listen and laugh. I check for straight neck, good intonation, low first fret action. I get the shop to adjust to how I like it there and then, this also tells me if the truss rod works or not.
About the guitar shops, I think the hardest part is going through the door and asking someone if you can try some guitars. Once you get going the time will fly by and you'll have a much better idea of whats available. Don't feel like you have to buy anything there and then and don't feel guilty for walking out empty handed, guitar shops are used to this, they want to make a sale but they're musicians too and understand your situation, they've been there too. In fact I would recommend not buying anything on your first trip, there's a lot of information to take in, go home and think about it all for a while, there's no rush.
Worst case scenario: You make some people you'll never see again feel good about how far along their playing has come! And if the guitar ends up being a mistake you can sell it on and probably not lose much anyway, it's all part of the journey.
There is is a guitar shop in Southampton the name of which I can't remember but they have a pretty good range. I would certainly advocate buying used and I think used on here is safer than eBay or gumtree although I have used both successfully.
The benefit fit of second hand from here is whatever you buy should be worth what you paid when you inevitably want to trade up again
you deserve the best you can get/afford/desire. being a beginner is not relevant to that, if anything it makes it more important. beginning is a special time. your wife has the cart before the horse.
I'm 2 years in and my opinion is
1) buy second hand as depreciation on new guitars is brutal (so avoiding it means you can move it on without a big loss if you buy well). I also think guitars with a bit of wear and tear are cooler, and you won't stress about adding the odd mark either.
2) don't expect to get it right first time, it takes time to get into the groove with a new guitar. (hence point 1, minimise the risk rather than fret about trying to find 'the one').
3) buy something you think is sexy, because the absolutely most important attribute it has to have is you want to pick it up every day.
how to do 1) ? Most sellers on here are sound (check they have a posting history other than on Classifieds, and read what they write, get a feel for the person). Some guitars have been bought and sold more than once, it doesn't mean there's anything wrong with them.
My Les Paul came from ebay but a few emails back and forth with the seller made it obvious he was an honest guy and a player not a flipper. There's a degree of risk of course, but I balance that against my PRS which I bought new, decided isn't really my bag and will take a 50% hit on when someone buys it.
(& I do like Les Pauls).
hth.
If you generally like the SG shape, I would try and look for a lower end Gibson SG and factor in some cash for a good set up.
My biggest success so far was about a month ago when I was noodling around with a simplified version of 'Wishing Well' from the RSL grade 1 book and she poked her head around the living room door to say "I actually recognise that".
It just happened that I'd been learning a Kenny Burrell chord melody version of White Christmas, so I played that for him. He looked at his wife afterwards and said, 'that was fantastic. It's my favourite song of all time'..........
'Somewhere Over The Rainbow'
Bastard.
LOL
You should probably have sung the first line to give them a clue.
I think my biggest take away from all this is that I need to conquer my fears and go and try some stuff, even if it's not initially on my short list. I can't do a comparison without doing the groundwork to have things to compare.
