Removing All Strings from Gibsons?
  • Thanks @Corvus ;
    Only a Fool Would Say That.
  • gusman2xgusman2x Frets: 921
    You guys are putting so much time and thought into this. It's crazy time. Don't buy a floyd.
  • richardhomerrichardhomer Frets: 24843
    edited November 2018
    The permanent ‘fix’ is to replace them with locking versions (such as Tonepros) which have hex screws allowing their height settings to be ‘locked’.
    Somewhere in the dusty corners of mind I thought Gibson fitted these as standard these days - obviously not....
  • ICBMICBM Frets: 72515
    I think they did on the Les Paul Standard in one of the recent years - although I forget which, with all the non-standard stuff they keep doing to it. I could be wrong, it’s hard to keep up with all the changes.
  • dindudedindude Frets: 8540
    I had a Godin with a bridge / tailpiece combo that was magnetised so that it stayed put. Very neat, although I'm sure that someone somewhere will suggest that the magnetism sucked out all the tone.
  • scrumhalfscrumhalf Frets: 11327
    Take pictures of everything when you start and as you go along. If the worst comes to the worst you'll at least have a record of what things should look like.
    Don't trust your memory, if the phone goes and you're away for fifteen minutes you may have forgotten where you were in the process.
    Upgrade to a TonePros locking bridge ... Gibson fit them as standard on some Les Paul models. They're better than the standard bridge and improve intonation, tuning stability and sustain.
  • 57Deluxe57Deluxe Frets: 7344
    ...seems a drastic way to keep it 'in tune'!
    <Vintage BOSS Upgrades>
    They are better than the standard .. I have them on my Gibson's. Not that expensive.
  • rlwrlw Frets: 4719
    Locking bridge and tailpiece every time.
  • teradaterada Frets: 5114
    Fretwired said:
    ...improve intonation...
    Interesting. Do they allow more range for the saddles than an abr1?
  • All done with the oiling, that was quite a painless method @Corvus ;
  • CorvusCorvus Frets: 2929
    Good stuff @Bellycaster quick & easy eh
