PRS necks query, Starla core vs S2
So, 3 PRS guitars:
2011 Starla Core, I assume 'wide fat' - way too wide feeling.
2013 Starla S2 - better, but shoulders feel biggish, not for me
2014 Mira S2 - great neck, measures as wide as the 2013 at the nut but feels narrower and more comfy.
My question: Could I find a Starla Core with the same neck as the Mira? I thought the S2 Starla would have the same 'pattern regular' shape, but even within a year's period it's different.
  • guitars4youguitars4you Frets: 14480
    edited December 2018 tFB Trader
    As far as I'm aware all the original Starla's had a wide/fat profile and the original Mira's had wide/thin or regular/standard so 2 options on the original Mira
  • grungebobgrungebob Frets: 3349
    I thought all S2’s had pattern regular necks? My Vela and Standard 24 where identical to each other.
  • CollingsCollings Frets: 412
    As far as I'm aware all the original Starla's had a wide/fat profile and the original Mira's had wide/thin or pattern so 2 options on the original Mira
    I thought the original core Mira were either wide thin or the old regular/standard neck profile.
    I owned a Mira with a regular neck and it was smaller than the wide fat or pattern.
    I agree but noticed an error on my text - Yes Mira was spec'd with an option of wide/thin or regular/standard - Corrected it and thanks
  • Philly_QPhilly_Q Frets: 23278
    As far as I know all the S2 models have the pattern regular neck, as you say.
    Having said that, I've got an S2 Mira, S2 Mira Semi-Hollow and S2 Singlecut Standard and they don't feel exactly the same to me.  The Semi-Hollow neck is definitely a bit thinner.
    Generally I find PRS necks a bit too Wide and not Fat enough.
  • allenallen Frets: 727
    I seem to remember the original Starlas had a shorter scale length too. Either 24.75 or 24.5 not 25 like the later ones.
    It's interesting, they are different at times even though presumably it's all done by CNC.
    Mostly CNC certainly, but also some hand sanding.
    In a way I'd expect the S2s to be more consistent than the core models, because undoubtedly the costings allow for less labour time.  But they still vary.
