Extension strip / socket
HootsmonHootsmon Frets: 15987
The 4/6 gang thingy for your amps and FX power on stage........
Just the regular garden type one that we use in the summer or is there are better more useful one for us special musos?
tae be or not tae be
«13
  • gringopiggringopig Frets: 2648
    edited July 2020
    5reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • ricorico Frets: 1220
    I use a boggo B&Q one but I’m sure there must be a more robust option? Maybe with surge protection etc.
  • HootsmonHootsmon Frets: 15987
    yeah i was wonderin' if there was a go to with extra features that we could do with
    You can get a surge protector that plugs into your wall socket, and then run your extensions off that.
    I got a Monster 6 gang jobbie when Richer sounds were knockin em out half price at £25.
    It has surge protection, though I mounted it to my wall at home as it/my gear never moves.
    You can get more expensive ones that also 'condition' or clean up the power if its dirty.
    Were rcd's recommended for live use?
  • HAL9000HAL9000 Frets: 9737
    As others have already said, get something with surge protection.
    Don't want to.put people off protectingbthier gear. But in the UK mains power is pretty reliable and surges don't tend to happen much. Digital gear can be more suceptable to flaky power whereas your 1950s valve amp less so.
    If you use generators or do festivals with suspect power a proper protection device is recommended at a cost under about £150.
  • Whatever you use always Test it  befor using preferably with a PAT tester but check simple things like  the terminal screws are tight correct fuse fitted and get a mains tester plug so you know it’s wired correctly. Brand new does not equal definitely safe and working properly.
    And @gringopig what benefit do you think you’ll get from that? I see that your based in Edinburgh. Do your amps run at 115 volt in which case you’ll need a step down transformer from 240 to use this? Or do you intend stepping down uk mains from 240v into this then stepping up again to 240 v.
    www.maltingsaudio.co.uk
    edited July 2020
    7reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • @gringopig sorry had my serious head on when I replied and didn’t read it as humour, no offence meant . I get a bit anxious when folks start discussing electricity distribution as I see so many dangerous ideas/ bodges at gigs and as the buck usually stops with me I tend to jump on everything.
  • Simon_MSimon_M Frets: 542
    BS7671 regulation 711.411.3.3 (Exhibitions, Shows and Stands):
    Each socket outlet circuit not exceeding 32A and all final circuits other than for emergency lighting shall be protected by an RCD having the characteristics specified in Regulation 415.1.1 (i.e. 30ma rated trip current, trips in 200ms at rated current, 40ms at 5 x rated current). So yes.
    (Am electrician)
  • Simon_M said:
    (Am electrician)
    Yeah... but what do you do in the afternoons?
    Simon_M said:
    (Am electrician)
    He stays at ohm
    20reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • LodiousLodious Frets: 1947
    hootsmon said:
    Simon_M said:
    (Am electrician)
    He stays at ohm
    edited July 2020
    edited December 2018
    hootsmon said:
    Simon_M said:
    (Am electrician)
    He stays at ohm
    If you like electrician puns, how’s this for starters?
  • EggmanEggman Frets: 43
    Simon_M said:
    hootsmon said:
    Simon_M said:
    (Am electrician)
    He stays at ohm
    Watt is going on?
    edited July 2020
  • scrumhalfscrumhalf Frets: 11346
    gringopig said:
    Joule find out in a second...
    Absolutely. Resustance is futile.
    Your electricity jokes are shocking...
