Strymon blue sky buffered?
skunkwerxskunkwerx Frets: 6882
Ello people smarter than I.
I see that the Strymon blue sky has a selectable mode between trails and true bypass.
In trails mode the website says its in a state of  analogue bypass.
Now, firstly can anyone explain the mechanics to a simpleton?
Does that mean that in trails mode, the pedal is bufferred?
I'd want this because I feel like a buffer at the end of my fx chain could only mean good things.
But that got me curious. How can a pedal be both true bypass and bufferred?
Is it like marshall pedals hardwire bypass? Not that i remember how that works though...
If Implement the blue sky in to my board, I'd be removing a boss ds-1 which sits 3rd from last, after an Ehx pocket metal muff which is also buffered.
The start of my chain is a Boss tu-3 so got a buffer there.
I know there are mixed feelings about buffers etc, I guess I just feel better having 1 at the start and one near the end, or in the blueskys case, potentially at the end..
  • Dave_McDave_Mc Frets: 2379
    I haven't tried that specific pedal, but I was under the impression (possibly wrongly) that to have trails you had to have buffered bypass.
    And if it's like any of the pedals I have tried where it has buffered or true bypass, it's not both, you have the option of one or the other (selected by a switch).
    Marshall bypass is just half-assed bypass, I think (the output disconnected when in bypass; true bypass has both input and output disconnected).
  • SnagsSnags Frets: 5420
    I assume it's like the TC Flashback X4 - it can be true bypass (and no trails) or it can have trails (and be buffered), depending on dip switch choices. But if it's in trails mode it's not true bypass.
    ^ Yep that's what I meant but I managed to phrase it less eloquently than that.. :D That's the way it is on my Digitech/Hardwire Delay and Reverb.
