Hummmm........
Just picked up an '03 mim Tele' on Reverb and it buzzes unless  ground it by touching something metal.
Any tips before I pull it apart and break out the heat shrink and copper tape?
  • jdgmjdgm Frets: 852
    edited January 2019
    Think you will have to go in and have a look - it could be as simple as the ground wire to the bridge not making contact, or a dry solder joint at the jack socket connections......
  • FunkfingersFunkfingers Frets: 14572
    The guitar may have been "repaired" or "upgraded" by somebody who did not really know how to do that properly.
    Equally, it may have been hurriedly returned to original spec immediately prior to sale.
  • ICBMICBM Frets: 72620
    Is it the month for this or something?
    Dry-joint January maybe?
    Uh...IGMC....again... :#
  • BeardyAndyBeardyAndy Frets: 716
    edited January 2019
    Hooked the control plate off last night and the joints all looked okay, and everything was where it should be. I was thinking about fitting one of the Home of Tone signature harnesses at some point so I may well just do it sooner rater than later.
  • Jimbro66Jimbro66 Frets: 2431
    While you are doing that it's worth completely shielding the control cavity too.
    Will do, I think I've got some copper tape somewhere if the wife hasn't used it all on her slug defences! =)
