The Answer Is Hot Rod Deluxe... Isn't It?
13»
  • MrBumpMrBump Frets: 1244
    Philtre said:
    Is one side shorter than the other?
    No, that's my house...
    Mark de Manbey
    Trading feedback:  http://www.thefretboard.co.uk/discussion/72424/
  • ICBMICBM Frets: 72339
    It's caused by the magnetic field of the speaker in the Fender bass cab.
  • Mark1960Mark1960 Frets: 326
    I have had a Blues Delux for several years. The clean channel is better IMHO, and I use a Thorpy Gunshot for drive. Covers most bases for a covers band guitarist except for Heavy Metal. Before that I had a peavey classic 30, but the Fender clean is better.
  • crunchmancrunchman Frets: 11448
    The Fender is a lot better built as well.
    Don't think there is much in it to be honest. The Fender is bigger and heavier, but apart from that both are pretty solid I would say
    No, the Fender is much better built than the Peavey. More reliable and also a lot easier to work on if it does go wrong...
  • PhiltrePhiltre Frets: 4173
    Ah, the Peavey's triple-decker PCB of doom....
    Having not had to take either to bits, I bow to your greater experience.
