Don't completely fill it with filler!
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
When I was working on this, I shaped a block of hardwood and glued it in. This pic is prior to any further shaping, grain-filling, etc,
What filler would be best ?
https://www.stewmac.com/How-To/Trade_Secrets/Patching_a_hole_in_a_1953_Telecaster.html
I have some hardwood that I can shape to size although I doubt I will get such a seamless fit as in that video so as not to need a bit of filler.
It is a cheap guitar that I am changing the pickup configuration on & then swapping pups & all hardware as I have enough parts lying around.
Also going to try swapping it from a six point trem to a string thru/T-O-M bridge set up.
I have swapped a lot of hardware & am fine doing that but have never touched a body, you may have guessed.
This is the guitar at present, an old Yamaha ERG 121 that I gave £20 for
It has a bridge pick up that doesn"t work, crackly pots & an unstable trem (presently blocked off) but is not in bad condition body wise, neck & frets are fine & I quite like the neck.
I have a few sets of HB"s laying around, plus locking tuners, pots, knobs, selector switches, a roller T-O-M, & output jack sockets.
The only thing I would need to buy really are some string thru body ferrules.
Just have to decide on hardware colour as I might change the guitars colour being as I will have to spray it.
Any suggestions on body/headstock colour & hardware colour greatly appreciated.
Any suggestions of a fixed bridge that will bring the strings around 12mm off the body ?
String spacing is 10.5mm or 52.5mm overall.
Apart from anything else, I suspect that the drilled hole, through which the output cable from the neck position pickup passes, connects all three pickup cavities.
I don"t really want to leave the cavity empty TBH purely for aesthetics.
Oh I see.
Although a lot more work I think I would prefer to fill the hole with wood.
I have to decide what I am going to do bridge wise next.
I have found a bridge that I think will give me the correct height off the body I need but not sure if it will give much sustain.
I fitted a steel block to the same trem on my Yamaha RGX as the original didn"t have much sustain & that greatly improved sustain over the standard zinc? one.
The fixed bridge above, I would imagine, will have as little or even less sustain than the stock Sun Il that is on the guitar at present.
EDIT: Thinking about it there is nothing to stop me using the above bridge string thru style, is there ?
