I don't know for sure of anything else that will even get you that close.
But then I'm not a DSP engineer.
The Eventide PitchFactor is a bit of a beauty too.
As I understand it, the OP is looking for a pedal that will harmonize in thirds in a given key (which requires an "intelligent" harmonizer"), but occasionally in fourths too (which requires unicorns).
ah ok I gotcha.
wear unicorn socks and do it with the pedal![;) ;)](/plugins/EmojiExtender/emoji/fb/3.gif)
If you were playing over a sequenced backing track it could have built-in MIDI messages that told the harmonizer to do different things at different times, but unless the harmonizer is being "told"- either by you or by some other pre-programmed source- what to do, it would have to somehow have the capacity to decide for itself.
Not too tricky when it only has one set of rules to follow (Here are the intervals of the major scale. Here is the key. Produce a tone a third above the note I play.), but asking it to decide whether thirds or fourths are more musically appropriate for each given note seems like it would need some serious computing power.
Technically it's probably possible (@WiresDreamDisasters does DSP stuff for a living- he might know better), but I'm pretty sure it doesn't exist yet as a thing you can buy.
Yes, but once again it isn't "intelligent", let alone able to switch between harmonizing in thirds and fourths.
I don't own one, but having skimmed the manual I don't think so- at least not without input from the player.
...although it does do a lot of other nutty things I'd forgotten about. Still want one. Still can't afford one.
soundcloud.com/thecolourbox-1
But the OP wants what he wants...
