Last year I discovered the benefit of using guitar supports whilst playing seated (which I normally do). They enable you to play with correct body posture, keeping both feet flat on the ground - thereby improving technique, playing tension and reducing tiredness and aches and pains (e.g. back pain).
I've tried several - including the Ergoplay Troster, the Gitano and the Dynarette cushion (which, although designed for right-handers, can be used for a left-hander like me, with a bit of imagination).
Up to now, my favourite has been the Dynarette as it is easy to swap between different guitars - although I sometimes have to use a small towel folded underneath to get the right height. There's also no need to worry about suction cups or the metal body of other supports which can scratch the guitar if the cups slip off (as a Gitano did with me).
Just recently I came across the made-in-USA NeckUp. It is a very simple concept but works really well. I've tried it on 4 different steel strung acoustics and 1 classical and it works superbly - comfortable, adjustable, stable and easy to switch between guitars. The smell (suede leather) is really nice too.
I'll still need to use the Dynarette for my Yamaha Silent Classical lefty conversion for the moment - but I notice NeckUp also do a narrow body version which I might try (and would also suit most electrics).
More details can be found at
www.neckup.com . They can also be obtained in the US through eBay and I also think there is a German seller (which saves the additional customs fees)
Acoustic guitarist users include Pierre Bensusan and Ulli Bogerhausen .
Hope this is useful
The NeckUp's main guitar connection is the strap over the end pin - with a single suction cup for a bit more stability. For classical guitars which don't have an endpin an additional suction pad (supplied) can also be used,
OK, so I'm going to sound like a complete numb-nuts here so don't unload on me but.......
Would wearing a short strap hold the guitar at a height/position that is comfortable to play at?
Would it not also allow the body of the guitar to resonate more without the contact on the lower bout?
I'm aware some of these devices have suction cups mounted to a plate which allows for more resonance but these knee lifters are the same as sitting the guitar on your knee.
Is there something about using a strap that is considered wrong?
Educate me guys....
These days I'm 90% nylon but those guys are a different world altogether. I had Philip Woodfield stick an end pin on my guitar so that I could use the neck-up. Judging by some people's reaction, you'd think I'd shat on the end graft! If it's not absolutely traditional and hundreds of years old (i.e. the way Torres did it), then it's crap. Welcoming lot...
