I have my eye on a cheap (and now discontinued, I think) multi-effect pedal that I would run in the effects loop for mod effects and reverb.
The pedal has only two jacks:
guitar input 1/4" Unbalanced (TS) Input Impedance: 500Kohm
Left/Right Output: 1/4" Stereo TRS Left/Right Output Impedance: 500 Ω per side Maximum Output: +7.0 dBu.
Website says "Amp/Mixer mode optimizes 1/4" output for amps and mixers", but I can't see anything in the manual, so I guess it must be automatic.
I won't be running it in stereo and I can't use 4CM as it only has 1 input jack.
Amp specs:
I can't find anything about one amps effect loop, but the other amp has a send output impedance of 4.7Kohm, return input impedance of 100Kohm. There are no switches of pots on these loops, so can't make any adjustments.
Will this pedal work in an effects loop?
Thanks for you time.
Ddig
It is cheap enough to have a go anyway. I will edit all the presets and remove anything that could add any gain.
Cheers, Ddig
