OR you could have a patch that included all the loops you need then turn the pedals off/on individually. I sometimes do this when I basically want to only add/remove a single pedal during a song. Otherwise, separate patches minimises the tap dancing.
Think I'll just have to get used to rubbing things a different way. Will be nice to be able to have some presets so I can minimise the tap dancing!
Do you have everything going through the PXL or would you put a fuzz before it?
From memory I've got:
Guitar > [Compressor > Overdrive > Distortion > Wah] > Volume > Amp > FX send > [Chorus > Flanger > Phaser > (Delay x2)] > Boost > FX return
Also triggers to the amp for channel/reverb.
