I've a few pedals, Brantone and some from Lumpy's Tone shop which if I put them in line with other pedals do not work.
I don't understand why.
This is annoying as they are such great bits of kit and I'd like to put together a board now I have most of my current faves in my ownership.
Help is required.
Thanks in advance.
P.S Assume you are dealing with zero technical or electrical knowledge and you'll be fine. I'm a dim whit on these matters.
If I had talent, I'd be talented.
Red meat and functional mushrooms.
Persistent and inconsistent guitar player.
A lefty, hence a fog of permanent frustration
Not enough guitars, pedals, and cricket bats.
USA Deluxe Strat - Martyn Booth Special - Epi LP Custom
FX Plex - Cornell Romany
Seeing that the Brantones seem to be vintage-style germanium fuzz pedals, it's quite likely that they need positive-ground power supplies. You can't use these in combination with negative-ground pedals on the same daisy chain or non-isolated power supply, even with 'polarity reversing' cables - you need an individually isolated power supply.
I need someone to set-up my board. Thanks for the explanation.
Is it a case that he pedals don't power up or that there is no sound passing?
Tate FX
www.TateFX.co.uk
Instagram
There is a power input.
It makes a strange sound but the other pedals cut out.
It's the tonebender variant pedal.
You need a new power supply unfortunately. Switching the polarity of the outputs won’t work.
Tate FX
www.TateFX.co.uk
Instagram
