Actually one thing that annoys me about the RE-20 is that there is no way of turning the tap tempo *off* again once you've engaged it, without moving the mode switch or the rate knob. Ideally a single press on the switch should do that.
But perfection is a type of character.
Plus guitars are inherently imperfect. Take a look at what a true temperament fretboard looks like. Several frets on the guitar are off on a normal guitar even if the string is in tune and you play with good technique.
