Chapman V2 Models at Andertons!
  • dindudedindude Frets: 8540
    Found a new factory that allows for more profit? Cynical me again
    There is a faint wiff of the old Bullshido about it
  • mondaypeanutmondaypeanut Frets: 72
    edited March 2019
    Played one and it felt like the materials were very cheap, melted down recycled cans for the bridge, one step away from a chipboard body etc, but someone had tried to set it up which had led to the main problem which was the buzzing all over the neck due to a noticeable bow to try to correct the neck join. Nothing to justify a £449 price tag, especially when you can buy an Epiphone Les Paul SL for £89 in the same shop and it's built better.
  • darthed1981darthed1981 Frets: 12028
    That might be the inconsisten quality Chappers was talking about at play.
    The one I tried was genuinely on par with a PRS SE Standard for quality, which I considered superb.
    How would you know the bridge was made of cheaper metal?  I mean it doubtless was, but assuming it was competently made, it should make no difference.
  • Played one and it felt like the materials were very cheap, melted down recycled cans for the bridge, one step away from a chipboard body etc, but someone had tried to set it up which had led to the main problem which was the buzzing all over the neck due to a noticeable bow to try to correct the neck join. Nothing to justify a £449 price tag, especially when you can buy an Epiphone Les Paul SL for £89 in the same shop and it's built better.
    The bridge seemed thin and lightweight and that's a problem for durability and also sustain which same reason people pay for brass tremolo blocks instead of cheap aluminium.
  • KalimnaKalimna Frets: 1543
    Genuine question - how would you know the bridge is lightweight if it was still attached to the body?
  • mbembe Frets: 1840
    That's easy, it's the aura of cheapness that reveals the inferior metallurgical properties and relative density.
  • What's so bad about scratchplates :dissapointed:
  • ArjailerArjailer Frets: 103
    1001 other companies do the traditional look if that's what you want, what's so bad about this one doing something different?
