Weird Hudson Broadcast Issue...EDIT - great service from Hudson and Northern Stompboxes....!
Musicman20Musicman20 Frets: 2337
edited March 2019 in FX
My Dual FS Hudson Broadcast has basically 1% output, if that.
It's been in its shipped bag and never even put on a board or gigged, so its absolutely immaculate.
I've finally got into a band and I want to use it this next weekend to record some basic stuff with them.
I went to try it this weekend on its own, straight after using the power supply with a Thorpyfx pedal, and it's got no signal.
Bypassed works fine. The LEDS light up. but zero volume or sound unless you crank EVERYTHING to 100% and then you can JUST hear a tiny noise coming out (sounds out of phase)
I've contacted @NorthernStomps and obviously I know I'll be sorted out by them or Hudson, but it IS weird....I'm stupidly careful with pedals and gear....is this just back luck?
EDIT: Taken Ytube vid down out as it is no doubt a one off and I don't want anyone to think this happens a lot if they search!
EDIT: Fresh replacement already on it's way directly from Hudson.
  • tone1tone1 Frets: 5180
    edited March 2019
    It’s got internal trim pots that are maybe turned right down
  • Musicman20Musicman20 Frets: 2337
    I've never touched them once... It was fine a few months back..
    Ah... sorry, thought you’d just bought it :)
  • Th4fonzTh4fonz Frets: 260
    Has it took a fall,  Maybe one of the transistors has come out of place?
  • NorthernStompsNorthernStomps Frets: 398
    Probably just a 1 in a 100,000 case of bad luck. These things are extremely well built
    Well get it sorted, no problems
    Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
    Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
    Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
    Strangely no... Its been in its bag that they come in in my guitar room and hasn't been plugged in for about 4 months...
    I see the problem, it's that boss katana.
  • LebarqueLebarque Frets: 3903
    Just one of those things. Occasionally something goes wonky. I'm sure Hudson will have it sorted quicksmart. Great ped.
  • TateFXTateFX Frets: 114
    Just a bit of bad luck, Hudson stuff is very well made.
    Probably something simple, I'm sure it will be fixed very quickly :)
    Formerly Stu_Tate
    Tate FX
    www.TateFX.co.uk
    Instagram
    As expected, Nothern Stomps and Hudson are on it already.
    I put this post up thinking I might have been doing something wrong! You never know...
    Anyway, what I can say is that when I opened the pedal up to see if I could see any signs of anything loose, it is gloriously well put together. Very neat and tidy.
    No doubt it's just bad luck.
    edited March 2019
    @NorthernStomps and Hudson have provided a great service.
    I have a replacement on its way and they will investigate the issues with potentially faulty one.
    Cheers!
  • Nothing less than what I expected from Hudson - I've had excellent customer service from them.
    No worries buddy, glad you’re all sorted
    I have some more Hudson stuff coming tomorrow as well including some Sidecars, which are also becoming difficult to get your hands on!
