Tele style guitar with heavy body/light neck
Is there a kit guitar, or manufactured guitar t style guitar with a heavy body and light neck, where adding locking tuners won't make the neck dive unreasonably?
Been using a kit guitar from gear4music at the moment and replacing parts like pick ups, nut etc
Thanks
  • Do Teles neck ever dive? I havn't played all that many but they always seem well balanced to me. Players usually are after lighter bodies where possible.
    I sometimes think, therefore I am intermittent
  • RolandRoland Frets: 8794
    Not dive per se, but the neck feels heavy if you go for a light body and use locking tuners. SG players wouldn’t notice. I’ve spent the last couple of years looking at ways round this, starting by using decent non-locking tuners, then making a body with a slightly larger (1/4”) upper bout.
  • Couldn't you just tape a bag of fishing weights under the pickguard?
  • FunkfingersFunkfingers Frets: 14622
    ON TOPIC
    Fender MIM Standard, G&L Tribute series ASAT Classic.
    VEERING SLIGHTLY OFF TOPIC
    TBH, on a regular Telecaster, with a fixed bridge and none of those B Bender / Palm Pedal / Hipshot multi-tuning systems, the only advantage that locking machineheads convey is speedy string changes.
    The G4M guitar kit product photographs appear to illustrate Jin-Ho R3 tuners. Compared to Schaller, Sperzel and similar quality locking tuners with machined gear casings, the Jin-Ho R3 is exceedingly light. The Wilkinson E-Z Lock tuners are the same thing with two holes drilled through the posts (and some rough edges to file down first!).
    HERE COMES THE SCIENCE BIT
    I used to have a slight neck dive issue with the Yamaha Attitude Plus bass guitar. My solutions were a high mass bridge and a grippy shoulder strap.
    edited March 2019
    I replied in the Making & Modding edition of this Discussion.
    Perhaps, the Modmins could merge them, please?
  • The gear4music guitar did seem to have a rather thick neck. I have thought about weights but there's not a whole lot of room under the pick guard.
    I like locking tuners I always find them easier and less likely to go out of tune
  • stickyfiddlestickyfiddle Frets: 27406
    The only neck-heavy Tele I've played is my own La Cab. Thinline body, huge beefy neck and locking tuners. Even then it's ok if I use a cotton strap. It's just the Souldier seatbelt-type ones that it's bad with.
    What's the body made of?
  • I replied in the Making & Modding edition of this Discussion.
    I have read your other post. I did buy a thicker strap which did help. The neck doesn't point to the ground.
    As I stated the neck seems thick compared to other teles but I was assured it was 9.25 inch
    The tuners that came with it are junk hence why I replaced them. I still have to put on a heavier metal pick guard so that might help
    Threads merged. I guess the message is “please don’t create duplicate threads”. Many people use Recent Discussions, so will see your thread. Duplicates just confuse people and irritate the moderators,
  • The only neck-heavy Tele I've played is my own La Cab. Thinline body, huge beefy neck and locking tuners. Even then it's ok if I use a cotton strap. It's just the Souldier seatbelt-type ones that it's bad with.
    Ash body https://www.gear4music.com/Guitar-and-Bass/Knoxville-Electric-Guitar-DIY-Kit-Ash-Body/WT3
    That's the link
  • JohnnysevenJohnnyseven Frets: 915
    edited March 2019
    Get a Squier CV 50's Tele. The body on the one I had was pretty heavy so should fit the bill.
    My trading feedback can be seen here - http://www.thefretboard.co.uk/discussion/58242/
  • rossirossi Frets: 1710
    I have a super light paulwonia  tele body on a Fender mex neck with gotoh locking tuners  and there is no neck dive.
    I may get a used squier or fender and transfer the parts in to that. Then re-do the finish
  • Sham61Sham61 Frets: 26
    I have a custom made Cabronita Thinline body which only weighs 3lb. The original neck I put on was too heavy and neck dived badly. I robbed the neck off a Squire CV as it was the lightest I had. Not as bad, though as suggested a good strap helps.
  • HenrytwangHenrytwang Frets: 473
    At 3.07kg my lightest Telecaster is a partscaster, it has a swamp ash body and an Allparts neck with a rosewood fingerboard. The hardware is pretty standard, Wilkinson Kluson copy machine heads, metal control plate and knobs and a Fender three saddle bridge plate. I’ve not had a problem with any sign of neck dive and I’m pretty sure that the addition locking tuners would not be problem .
  • I'll have the post pictures as the neck doesn't point to the floor but is almost horizontal and feels like I'm lifting the neck to play it comfortably
    Or tie a couple of helium balloons to the headstock?
  • Squier John 5. Proper heavy.
