Wondering if anyone can help me with this. Sorry for the appalling photo but my Blues Deluxe has this board attached to the metal speaker frame by a rivet. It has two spade connectors coming out of it and two bare wires disappearing off into the speaker cone.
The rivet has sheared off and now the board is flapping around and shorting out the amp when it touches the metal speaker frame.
I was at practice last night when it happened so I just wrapped the part in a load of electrical tape.
What is this bit and how should I best repair it?
While you’re at it, if you have a soldering iron, solder up the two small crimps that hold the cone braids - they sometimes make a bad contact. I personally like to cut the push-connectors off the cable and solder those too, but you may think that’s overkill.
