The amp normally sells for only about £500-£700 otherwise.
Feedback : https://www.thefretboard.co.uk/discussion/58125/
It looks to have had a badge at the top right of speaker cloth, any ideas what that might have been?
If the amp has been fitted with 1-ohm bias check resistors then you can bias it *fairly* easily yourself, although it's still potentially dangerous. If it hasn't then you will need an external bias 'probe' adaptor, unless you want to measure the voltage drop across the OT... not really a great idea if you need to ask about this sort of thing! 26 and 28 are close enough not to worry about it though, especially if you're running the amp at '260V'.
JJs are good 6L6s, they're about the most robust of the modern ones.
Yes, I have worked on a lot of these amps . Twins were very common in working bands thirty years ago.
If you get nervous I could probably arrange a site visit .
