If you could only have one pickup, would you choose bridge or neck?
13»
  • TeleMasterTeleMaster Frets: 10286
    edited April 2019
    Bridge pickup all the way on Teles and Les Pauls. I rarely use the neck. I use the neck/middle on my Strats. You need something to cut through and the bridge is normally better in my opinion, unless the bridge pickup is too bright, which can be the case on Strats.
    Bridge. I hardly ever use neck pickups apart from a Strat on neck and middle pickup setting.
  • skippy76skippy76 Frets: 616
    Neck on a strat and bridge on a tele or LP for me
  • BlaendulaisBlaendulais Frets: 3325
    Definitely bridge. I think im a bit deaf and need that top end!
    As you age and lose your higher frequency hearing thats what happens. The worse thing in the world at gigs/jam nights is oldies playing with massive tinny treble unaware those under 40 are in agony from all the high frequency
    Note to self...turn down treble till it sounds muffled and it is bright enough  for anyone under 40
  • DrBobDrBob Frets: 3007
    Bridge. I have no real need of a neck pickup to be honest.
    /\ What he said!
    Exactly right
  • NeilNeil Frets: 3641
    Gibson - bridge
    Fender - neck.
  • WhitecatWhitecat Frets: 5452
    Neil said:
    Fender - neck.
    Even on a Tele??
  • GreatapeGreatape Frets: 3609
    DannyP said:
    I can't believe all you neckies!
    Neck pickup is the bedroom pickup.
    Yep...Hendrix and all those bedroom gigs he played.. :)
  • BlueingreenBlueingreen Frets: 2612
    If pushed, neck.  But I'm very much a two (or 3) pickup guy.  I'd never want to own a one pickup guitar.
  • TTBZTTBZ Frets: 2914
    /\ What he said!
    Exactly right
    And me. I might occasionally use the neck pickup for messing about on some clean stuff but in my band it's never used. Still meaning to set my SG up as a "standard jr" with just the bridge humbucker..
  • chris78chris78 Frets: 9396
    My favourite guitars are teles. What’s a neck pickup?
  • digitalscreamdigitalscream Frets: 26792
    Bridge, because some of the pinched harmonics I use result in very little vibration over the neck pickup (some to the point where they won't actually make a sound). Those nodes are smaller over the bridge pickup, and thus there's less variation in amplitude.
    Also, you can sorta-kinda use a standard tone control to make a bridge pickup have neck pickup-like aspects, but the reverse isn't true.
    <space for hire>
    Mines an Esquire since I did away with the shiny ornament in the pickguard.
    I can go further... than neck or bridge. I know the specific model of pickup.
    If I could only have one pickup it would be an Oil City Alligator 90 bridge pickup. It’s a wonderful thing and I can always find “my” tone with it.
    TTBZ said:
    /\ What he said!
    Exactly right
    Neck pickups are fine for those occasional moments of “quiet contemplation” they’re definitely a nice to have rather than a must.
    Except for Jazzmasters, then it is a neck pickup thing
  • KittyfriskKittyfrisk Frets: 19038
    Today, I are mostly havin the smart solution  ;)
    http://wilkesguitars.co.uk/instruments/the-answer/
  • richardhomerrichardhomer Frets: 24851
    On a Strat - if I had to go for one - the middle....
    Whitecat said:
    Neil said:
    Fender - neck.
    Even on a Tele??
    Oh sorry, meant a Strat, don't own a Tele.
  • Dave_VaderDave_Vader Frets: 360
    Neck, tone down a lot for clean, bridge , wide-open for dirty
    If I could find a footswitch to do that at the same time as engaging my RAT life would be much simpler.
  • 57Deluxe57Deluxe Frets: 7345
    Check-up from the Neck up... For those Necky tones you just pick a Bridge PUP up on the fingerboard.
    <Vintage BOSS Upgrades>
  • LebarqueLebarque Frets: 3905
    Eh?
