Digital multicore over Cat5?
  • JalapenoJalapeno Frets: 6398
    I'd definitely recommend putting conduit down so you can pull additional cabling through if you need it, which ever solution you choose.
    This. Muchly.
    Even if you don't need it immediately, I'd put a CAT5 link in place regardless, it'll be very handy.
    Feedback
  • robinbowesrobinbowes Frets: 3054
    I've not used these products but they look interesting
    http://soundtools.com/products/catfamily.php
  • spark240spark240 Frets: 2090
    100mm duct is always good for future expansion...
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • TrudeTrude Frets: 915
    Sounds sensible, but how do you go about feeding another cable through after the duct is buried?  It's going to be about a 16m run with at least one 90° bend (not including the gradients to drop down and come back up to the surface)
    Some of the gear, some idea
    Trading feedback here
  • guitartangoguitartango Frets: 1028
    If you are laying CAT5/6 outside you really need the armoured version and it't not that expensive. I have seen rats/birds go through normal cat 5
    “Ken sent me.”
    Yes, it'll be armoured cable and about two foot underground.  Since I'm laying power cable too it all has to be fully up to regulatory standards.
    You run rope through the duct so you can pull cable through later.
    Also, most electrical installers have rods they can use to push through ducting to pull cables through.
    R.
