And the bridge for the correct radius
Bear with me
The difference in fret positions between a Jaguar (24"-scale/22-fret) and a Jazzmaster (25.5"-scale/21-fret) neck is actually one full fret at the *headstock* end. Fender always used the same overall fret spacings, but adjusted the start and end points to fit the different models.
So that means that a *23*-fret, 25.5"-scale neck will fit on a Jaguar body perfectly. Now imagine the same thing with an extra-fret overhang like a modern Strat, and you have a 24-fret, 25.5"-scale Jaguar.
The bad news is that you'll almost certainly have to have such a thing custom-made, but if you did it could also have a Wizard profile, large-radius board and big frets...
Unfortunately, on a regular Jaguar body, the bridge, mute and tailpiece positions will be at the wrong distances from the end of the neck pocket to work with the 25.5" scale length neck.
A 23-fret, 25.5”-scale neck would be the same as a Jaguar neck but with an extra fret at the headstock end. The bridge will still be in the correct position.
It’s the same as the 24”-scale/22-fret and 22.5”-scale/21-fret necks used on the ‘student’ guitars - they’re perfectly interchangeable. I swapped two of them and didn’t even need to adjust the intonation on either guitar!
