55 year old nitro.
  • jimmyguitarjimmyguitar Frets: 2475
    Definitely don’t strip it before you’ve tried everything else as it does look like the original finish.
  • musteatbrainmusteatbrain Frets: 883
    I’m not sure what it is. I think maybe someone put something over the original finish many years ago.
    I used carnauba wax just now after testing on a small patch
    https://imgur.com/a/dKte0XX
    It turned really oily straight away and most of it seems to have come off with a rough old cloth
    Now wondering if it was some polish from before I owned it that had reacted with the nitro and remained on
  • IvisonGuitarsIvisonGuitars Frets: 6842
    Are you sure it’s not just grime you’re scratching off? I think if you used a decent guitar cleaning product like Virtuoso cleaner and polish you’d get it all off with a bit of elbow grease and back to the original finish.
    As Jimmy says, have you tried cleaning a small patch with lighter fluid/‘naptha’. I’d definitely be trying that first before anything else more drastic.
    http://www.ivisonguitars.com
    (formerly miserneil)
    Thanks. Have done that too now.
    seems much better
    seems much better
    Good stuff!
  • HenrytwangHenrytwang Frets: 473
    Interesting.. I’ve got a 70s Les Paul Deluxe that always seems to have a slightly sticky feel to the Back of the neck that I’ve never been able to get rid of. Maybe I’ll give the lighter fuel a try.
  • KittyfriskKittyfrisk Frets: 19303
    ^ Just remember not to use the Hendrix technique.
    I’ve been tempted with this guitar. It’s a typical 70s Les Paul, maple neck,  ugly volute at headstock, body made out of several pieces of wood and weighs a ton.
    Be more positive. Maple necks are supposed to be 'snappy & responsive'.
    The volute gives strength to a fragile joint.
    Weighty multi piece bodies give strength & sustain.
    Everyone knows these truths to be self evident  ;) ;)  :)
    Besides, it is a product of its time, that's how they were built, so it has 'original vintage qualities'.
    Learn to appreciate it, or get rid of it  :)
