Wetterbox = £229
Aside from the ability use an expression pedal for live blending... meh.
Regarding the comment about buffers on the G2... genuinely, I've not noticed any issues or difference in tone whatsoever. And I'm super sensitive about such things, especially with my old Tele. Plus the modular power system is FAR FAR FAR lighter than any of the single box systems on the market that produce similar power (not important to some, massively important to me) and solved all of my ground-loop and noise pickup problems on my board. Horses for courses and all that. I would agree that as a system the Gigrig is expensive but for me, it solved *every* issue I had and is just super-reliable.
But I do agree about this pedal being a bit more than a bit... er... "wtf, you can do that a lot cheaper elsewhere".
worth more now
https://reverb.com/uk/item/2045822-the-gigrig-wet-box
It's just too impress his famous guitarist mates I think.
The pedal itself is a cool idea, I just struggle to see how practical it would be on a "permanent" pedalboard- I can see all sorts of ways it would force you in to compromises- either you're limited to one pair of blendable pedals or else you put multiple pedals in the loops and have to deal with the problems that come along with that...
It seems more suited as a "studio" pedal for experimenting and finding interesting sounds as a one-off rather than anything you'd integrate into to a gigging board. Which in practice probably means that it ends up as an occasional "shits and giggles" pedal.
What would be awesome would be if the next generation Gigrig switcher had the same functionality built in, assignable to different combinations of loops, which would be much more practical for a gigging board.
The morningstar had confusing dual press options I could never remember and even at its its eat switching time the messages arrived slowly.
Otherwise it's quite limited what it can do unless you want to constantly re-organising your board or have 2 loopers, 1 on each side and double up your effects just so you can choose what to blend….which goes back to my first sentence…need 2 boards.
My music:- https://soundcloud.com/hubobulous
