Secret Delay setting
HootsmonHootsmon Frets: 15962
What's your go to secret delay setting (not a tap or tempo dependent setting) for that special solo of yours?
Or perhaps it's your always on setting or slap back....something that works every time that does not have to be dialed into tempo
settings please in Ms  FB and mix
Thanks Guys  :)
tae be or not tae be
  • HootsmonHootsmon Frets: 15962
    Some guys have something like 400ms banging away all the time.........how does that work?
  • FunkfingersFunkfingers Frets: 14424
    edited May 2019
    The secret word for tonight is Phaedo. Arf for arf’s sake. :)
  • KeefyKeefy Frets: 2286
    edited May 2019
    On the original Boss DM-2 and DM-3, point all the control knobs towards the LED to get the 'perfect' slap sound. So that would be approx 150ms, delay level 50%, feedback level 25%. These probably won't work so well on a digital delay unless you can set a low pass filter on the repeats with a cutoff around 3kHz.
    Interestingly (to me anyway) to get the same delay time in the Standard mode of the DM-2w you need to set the Rate control to half-way - different pot taper I guess.
  • darthed1981darthed1981 Frets: 11754
    I like to turn the delay and distortion right up, so you cant hear me screw up the solo ;)
  • WazmeisterWazmeister Frets: 9532
    The 'Simple Delay' on the HX Stomp - set to just one repeat and low mix (about 28%).
    It just adds a little bit more and a 3 dimensional kinda sound.
  • prlgmnrprlgmnr Frets: 3988
    Good old Lexicon Circular Delay
  • robgilmorobgilmo Frets: 3451
    I just play out of time with every thing else.
  • stonevibestonevibe Frets: 7142
    https://www.facebook.com/100000431326746/videos/2376749105682777/?t=12
  • vizviz Frets: 10691
    I think actually that's the most realistic approach - don't set it in time with the song, have it at a tempo that gives the right ambiance for you, after all if you were playing in a cave there would be a certain echo tempo regardless of the timing of your song :)
  • RolandRoland Frets: 8704
    154ms for a “barely noticeable” delay, and 5ms for the full monty solo
    Get him, lads.
    350ms ish, 30% wet 3 repeats works well for me on rock stuff, 200ms one repeat for country stuff
    I haven't switched my delay pedal on for at least five years. I wonder if it still works.
  • GassageGassage Frets: 30912
    480 into 720. Lush as fuck.
    Does that work for Western stuff too?
    Then you'd have both kinds of music covered.
    I have 1/4 note slap on for solo’s and dirty textures. I also run 2 delays at the same time. 1/4 note & 1/8.
  • DominicDominic Frets: 16095
    a DUCKED DELAY on about 480 works for everything and never gets too congested or confused.
    Brilliant type of delay and it still fattens .......if you shorten it you can get a vaguely double tracked effect without it getting messy.
    Ok, I'll ask ... WTF is a DUCKED DELAY ? ;)
    Feedback
