Bought a Highway 1 Strat off ebay which arrived today, very nice guitar, checked it all over tumed it up, electrics all working, so went to set it up to my preference, a bit too much neck relief, so out with the allen keys, couldn't get one to engage in the truss rod nut, out with a torch...no adjuster nut, truss rod has sheared, no sign of the nut!
Shame, nice guitar, looks to have had very little use, bugger...its a really nice guitar, USA made, with a scrap neck!....
Have messaged the seller, to see if he will refund enough (£200) to buy a new neck....this is how it arrived, amazed it wasn't damaged on transit.....
http://i.imgur.com/w22OuhZ.jpg
Stranger from another planet welcome to our hole - Just strap on your guitar and we'll play some rock 'n' roll
http://i.imgur.com/VaaVl79.jpg
Most annoyingly its in otjerwise really good nick, zero fret were, one scratch on the upper horn, it is otherwise unmolested, setup was apalling, appears to jave been owned by smeone clueless and hardly played, then they broke the truss rod......it a lovely neck....such a shame......just needed a good clean, fret polish and a setup......bugger!
I guess ebay will side with me if a partial refund is not forthcoming......
Are you certain you're using the right size Allen key? It *must* be a 1/8", *not* 3mm or 4mm. Of course it is possible that the previous owner has already used a 3mm and stripped the socket, which is why it won't feel like it's locking in.
Was just about to say^^. Stewmac Gripper might work if you're lucky, it did on mine just barely but I replaced it anyway because I wanted to refin the whole guitar neck and all. A PO must've used a 3mm and knackered it. Pic to show the nut etc
http://alleykat.co.uk/images/stuff/strat/7_tr_nut.jpg
a) there
b) 1/8"
c)the truss rod works
and
d) I've apologised profusely to the seller
I feel terrible!.....
Good result though, especially if the guitar is otherwise perfectly fine. I've had proper facepalm moments like this before (usually preceded by that horrible sinking feeling that an exciting purchase is turning out to be a nightmare). Enjoy the strat!
I actually put tape round one end of my 1/8" allen key to distinguish it
I've got to the point now, that if I trade in any USA model, with the truss adjustment at the top nut end I check them first, for such an issue
The only reason for it to be like that is to make the rod double-acting, and that's so rarely ever necessary - I've needed to reverse-tension a rod just once in all the time I've ever been working on guitars - that it causes a problem far more commonly than it solves one.
The 70s 'bullet' nut was a far better idea - it's still a 1/8" key socket, but if it gets damaged you can get the nut off fairly easily.
I still feel terrible, however the truss rod allen hole was stuffed full of compacted dust...
I've cleaned it up, had to resurt to T Cut on the body as it was filmed with something that wouldn't come off with a damp cloth. The fretboard was drier than a dry thing so that got Lemon Oiled, I swapped out the Scratchplate for another to retain the original protective film and stickers that were still present and bagged up the original with the Trem spring cover and its screws. Added two springs to the Trem and decked it. While under the bonnet, I fitted a treble bleed to the volume pot as I always do to my Strats......
It was factory wired with tone on neck and bridge, no middle tone which is how I like it, forgot to look and see if the tones are Greasebucket as I think they should be.....
I was the first human under the hood, you could tell by the tightness of the screws.....
Seller said it was bought and hardly played and just hung on the wall since 2006, it wouldn't tune against the trem springs, as received the setup was terrible, so that sort of fits with no use as does a lack of playing wear...
I'm chuffed as nuts, a great sounding made in USA Nitro finished Highway One Strat......
