Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
Hard to tell in the pics but staggered pike pieces would be 73/74 and flat pole pieces 75 on and black pickguards cane in around 75.
I love the '70's natural look even though it has been stripped.
Re the stripping, perhaps somebody dropped the body in an acid bath (very common for pine doors in the '70's) or used some harsh chemicals that affected the glue and caused the body joints to come apart?
Bridge is non-original, and obviously either the pickguard or the pickup covers aren't... or both.
Should have bought more of them at £200 a pop and stuck them in my wardrobe!
For 1975, the serial number ought to be stamped into the neck anchor plate, between the two screws.
The bridge saddles are not original but you probably already knew that.
Any date info on the neck pocket, possibly the pick-ups if any, + butt end of the neck will be useful
Weight-wise, it's actually OK...
Switch is 5-way.
