Battered, but plays well (Vintage Strat Content).
  • ICBMICBM Frets: 72846
    Weight-wise, it's actually OK...
    Because it lost a pound when the Thick Skin finish was taken off :).
  • FunkfingersFunkfingers Frets: 14646
    ESBlonde said:
    I'd suggest a fret dress rather than a refret. Those maple fingerboards can splinter and delaminate the finish if the refret is not done by a very competent luthier.
    The 1976/77 example to which I referred earlier is shedding fingerboard finish all on its own.
  • guitars4youguitars4you Frets: 14560
    edited June 2019 tFB Trader
    Because it lost a pound when the Thick Skin finish was taken off .
    Valid comment - I've not done it for years - But recall weighing a thick 'dulux gloss' style finish that I took of a refin SG once - Weighing the actual finish/debris etc
  • HarrySevenHarrySeven Frets: 8038
    Well, I’ll update when I go back next week...
    Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • p90foolp90fool Frets: 31778
    My CBS Strat's neck finish is falling off in sheets...
    http://i68.tinypic.com/24mrzhs.jpg
    http://i64.tinypic.com/mcgp5c.jpg
    But first...to recap.
    What we know so far:
    *Stripped finish
    *De-laminating body
    *Badly chipped neck finish
    *Neck - Post-‘71 (3-bolt)
    *Neck plate - too late for the neck (no serial)
    *Neck - Pre-‘77 (no S-Prefix headstock serial)
    *Non-original bridge
    *Non-original saddles
    *Non-original switch - 5 way (post '77?)
    *Pickups/Scratchplate possibly non-original
    *Trem cover - non-original
    Despite all of the above, plays well.
    Body: not *that* heavy
    Neck: Slim
    Potential dating factors:
    *Pot codes (*If* original)
    *Pickups (*if* original)
    *Neck pocket
    *Neck heel
    *Body routing
    Have I missed anything? ;)
  • KoaKoa Frets: 122
    There’s often a serial number label on the underside of original guards.....
  • NPPNPP Frets: 236
    edited June 2019
    mine doesn't have that but it has a sticker in the neck pocket.
    It also has the paint chipping off the fretboard but it never peeled away as in @p90fool 's pic above (but I sanded it off in about 1989)
    My 1978/79 P Bass has a date stamp in the pickup cavity.
    Neck is pre-76 (year and serial number prefix).
    Body being ash rather than alder suggests no earlier than 1972.
  • But first...to recap.
    *Stripped finish
    *De-laminating body
    Neck: Slim
    *Neck pocket
    *Neck heel
    *Body routing
    Not far off from Trigger's Broom!
    I sometimes think, therefore I am intermittent
    So...a return visit was made...
    ... and ...
    edited June 2019
    *Pot codes - Vol and Middle Tone = ‘74
    *Pickups - Neck and Middle = ‘75
    *Neck pocket - ‘SAGE’ name - matches other examples online (approx ‘75)
    *Neck heel - ‘R. BUSH’ name-matches other examples online (approx. ‘74/‘75)
  • richardhomerrichardhomer Frets: 24862
    That trem cavity doesn’t look right - never seen a factory one look that rough - even from that period. The ground wire hole is in the wrong place - so my guess is it was a hard-tail which has been converted.
    @richardhomer - this was precisely what I was about to say...
    edited June 2019
    Summary, so far...
     *Stripped finish
    *De-laminating body
     *Poorly-routed body (hardtail
      conversion). Approx ‘75 - see below.
    *Non-original bridge/saddles
    *Scratchplate - possibly non-original
      (matches other examples online - approx ‘75)
     (matches other examples online (approx. ‘74/‘75)
  • PVO_DavePVO_Dave Frets: 2380
    Then blocked off!
    Maybe it was a weight saving exercise :D
    That’s a very poor trem conversion unfortunately.
    I would not pay a lot for it, it has very little real value other than in the neck and the original electrical parts.
    edited June 2019
    @richardhomer, @PVO_Dave, @ICBM - I did wonder on my last visit when I could see some kind of ‘damage’ to the body at the side of the trem cover.
    All became apparent once I removed it last night and my heart sank! :(
