Both the volume and tone controls on my guitar have started crackling (when rotated) and I was hoping that someone might be able to offer a suggestion for the most likely source of the problem.
This is a recent development; they both function fine besides this and it doesn't seem to momentarily 'cut out' completely. I have next to no experience in this area of maintenance but I'm guessing that either the shafts on the pots or some soldering which has seen better days are possible candidates?
This is how the cavity looks:
https://imgur.com/a/aXvKstn It's a Wolfgang with a pair of humbuckers, one volume and one tone control
https://imgur.com/a/VgTfE1x
Usually crackling pots are just dirt and debris, plus static making them noisy.
This stuff will clean them and not damage the lubricated contacts.
https://www.amazon.co.uk/Super-10-switch-cleaning-lubricant/dp/B001DQ1FHM
DO NOT USE WD40 FOR THIS JOB.
Thanks both.
@stonevibe I've ordered up a can of the contact cleaner you've suggested and hopefully that will do the trick. It will be handy to have around anyhow. Lucky you mentioned WD40 being off limits as I have some of that knocking about somewhere. I'm leaning towards this or something like it being the answer to be honest. Other than when I adjust either of the controls all is well.
@ICBM
>>> "What are you plugging it into? "
It's one of those Hughes & Kettner Tubemeister mini stack jobs. Admittedly I haven't tried it in anything else (I have a Vox which tends to be more sensitive) but I didn't manage to reproduce it with either of my other guitars/cables. I'll revisit this and drop a pedal in between too. I only have the less fashionable buffered Boss ones but I'm guessing that won't matter?
And for everything else .
