Metal guys with single channel amps
EddieVNEddieVN Frets: 1
Guys like Zakk Wylde & Kerry King who use a single channel head live – what do they do for a clean sound? Do they have another rig and an AB box? I was watching a youtube video of Kerry King taking you through his live rig and he’s running three of his signature heads (which is single channel) with slightly different EQs for his distorted sound but didn’t mention his clean sound… anyone know what he does?
  • John_AJohn_A Frets: 3775
    edited June 2019
    Apparently for a clean tone for Kerry King  it's DI guitar direct to FOH
    Does Zakk ever use one?
    Yes - I'd imagine it's probably DI... May be wrong though.
  • fretmeisterfretmeister Frets: 24286
    ZW turns off the overdrive pedal and then turns down his guitar volume.
  • musteatbrainmusteatbrain Frets: 877
    Yep as above
    About 4:30 on this for Zakk on his clean tone
    https://youtu.be/2Jd0zypZlXY
    Maybe they use a mixture of amps and A/B between them
  • ReverendReverend Frets: 5001
    Clean tone???
    I'm lost.
    3reaction image LOL 0reaction image Wow! 5reaction image Wisdom
  • ICBMICBM Frets: 72364
    Almost all pro guitarists use two different amps, or an amp and a DI box. This is so that there can be two completely separate mics/feeds to the desk so each can be EQ'd and level-adjusted separately, so the soundman doesn't have to keep adjusting things every time the player changes sound. Even the ones who use channel-switching amps will have two of them, one set to each sound and selected externally.
  • steven70steven70 Frets: 1263
    edited September 2023
    k
    steven70 said:
    Can tell you one thing- whatever he does, most of those amps on stage are dummies. Several years ago we ended up right at the bottom of the bill at a heavy rock thing he was headlining and I tried to use one of his "Marshall stacks"
    Yep. All the heads on stage are dummies with a powered up light and a short lead plugged in. two heads and two cabs was his actually set up with the heads set up in the guitar world behind.
    I was trying to be funny ;)
    I thought you were asking if ZW used a DI!
    No asking if he ever used a clean sound (in a tongue in cheek way) :)
  • TTBZTTBZ Frets: 2898
    Metal with clean guitar is the wrong kind of metal.
  • Modulus_AmpsModulus_Amps Frets: 2580
    I have made a few dummy head cabs, from far you would not know that they are not real.
    Interesting, I never thought about this much, but that makes perfect sense
    Metallica are using Axe-FX... and even then they have 1 unit for for clean and another for dirt, and another for solos etc etc
    Their Rig Rundown goes through it - removes any chance of patch change delay
  • MonstronautMonstronaut Frets: 193
    Kerry King's clean sound is never actually clean. There's still a fair amount of hair. I'd imagine he just turns the volume on his guitar down. That's what I do when I want a clean sound on my 2203.
  • RobDaviesRobDavies Frets: 3067
    I’m trying to think of a clean part on the first five Slayer albums..... the intro to Spill The Blood is all I can come up with, and I think that was Jeff?
  • Kerry uses a chorus pedal into a D.I for his clean tone. He does the clean intros for Seasons, spill the blood and 213
