I’m thinking of getting a second amp - something not overly large, and something classic looking.
I quite like the look of a Fender Blues Junior in lacquered Tweed, but have only heard them in video demos so far.
I’m only after something for home use, that I can pop a couple of pedals in front of - got a bigger amp with a Helix for Sunday best.
In the course of my research into them, I discovered a company called Rat Valve Amps in Cornwall who do loads of mods to them.
https://www.ratvalveamps.com/fender-blues-juniorSurely, for an amp so popular...they can’t be as bad out the box, as that website makes out, right?
My thinking is that if I needed to spend another £500 to make the amp better, I should just buy a better amp to begin with.
So, my questions are:
1. Are they THAT bad to begin with?
2. Would some/all of the mods listed on the website, make it loads better?
3. What are viable alternatives (similar footprint, low power for home use, takes a couple of pedals well?)
Seen recommendations for Marshall Origin 20 and I’m already feeling a bit ‘meh’ with what I’ve heard.
Might be tempted by non-valve too....Peavey Bandit or maybe a Blues Cube?
I don’t have a gambling problem, I’m winning, and winning is not a problem for me. That’s like saying that Iron Maiden have an awesomeness problem.
That said they are better at low volumes where you can dial the mids out, which you can’t as much at higher volume where the boxy-sounding cabinet overrides everything.
The build quality isn’t great either - in particular the pots and jack are flimsy, and they also have a bit of a tendency to catch fire due to poor PCB design, although Fender have finally started to do something about that.
Personally I probably wouldn’t even look at a valve amp these days for low-volume use, given what else is available. I even prefer my nearly 20-year-old Peavey Studio Pro to most small valve amps.
i like the sound of blues juniors but already have a valve amp at home.
If if you want to drive the amp to break up at home you need small like a 1 watt black star. I think a larger valve amp,Princeton or AC10 with pedals sounds better than driving a small amp, and better than the katana but I don't need any pedals with that which is appealing.
It has bumped a Princeton Reverb II back into storage - similar footprint but sounded a bit dull when A/B'ed together. Both are too loud for family life though - I just plug into a THR10 for quiet practice
In my opinion they are OK at lowish volume. I played through one at a gig at then end of last year and it was not a great experience to be honest.
What are Bassbreakers like then? Can’t seem to find anything online about them being ropey. I played one at PMT in Cambridge a couple of years ago...rather good, but I was focussed more on the guitar I bought.
It gives the ‘Feel” of a valve amp, nobody could ever tell you it didn’t sound like one.
The thing it doesn’t have is as much dynamic range which I think makes it better at home than any valve amp as you don’t have sudden spikes in volume whilst jamming to tracks etc.
I’d also look at @icbm ‘s suggestion of a small Vox. My (admittedly limited) experience of them is that they sound good, and are surprisingly loud.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
