Fender Supersonic hiss update: too few mu?
DannyPDannyP Frets: 1679
edited August 2019 in Amps
I picked up a 2nd hand Fender Supersonic 22 yesterday and it's just the ticket for my needs.
But it's noisy.
My ISP Decimator noise gate in the effects loop totally cures it, but it's biting off the reverb trails.
So the reverb comes before the effects loop? Is that standard? Wouldn't it be more sensible to have it go after the loop if possible?
So I guess my options are:
1: some sort of mod to lower the noise?
2: some sort of mod to put the reverb stage after the loop?
3: use a reverb pedal in the loop after the gate.
Does anyone have any thoughts? Thanks in advance!
  • Pedal tingz m8.
    Bye!
  • DannyPDannyP Frets: 1679
    Pedal tingz m8.
    I was trying to avoid an extra pedal, and I like the reverb on the amp, but might have to...
  • ICBMICBM Frets: 72376
    It depends on the amp. I would guess it's more common to have the reverb before the loop, since it's easier to implement if the loop is a typical after preamp/before power amp type - although it would be more logical from an effects-order point of view to have it afterwards.
    Modding the amp to swap them is unlikely to be simple, if feasible at all.
    Is the noise from the amp from just the overdrive channel?
    The noise is the same on both channels and solved with the NG in the loop for both channels.
    Is it related to the reverb itself? It must be coming from somewhere after the overdrive channel if it's not worse on that than the clean channel.
  • deaccideacci Frets: 41
    Had a friends doing something similar. the  noise disappeared if some weight was applied to.the top.of the head. So we took it apart assuming some sort of loose ground connection. After some digging   it turned out to be a damaged coil in the reverb tank. Try  unplugging the reverb tank and see if the noise goes away .
    Declan Larkin  |  Deacci Guitar Pickups
    www.deacci.com  |  +44 7799 417775
    Many thanks I'll try that!
    I've been trying to upload a vid to Imgur to demonstrate, but couldn't get it to work.
    edited July 2019
    Disconnecting the reverb tank makes no difference to the noise level.
    I think it might just be a noisy amp due to something that both channels share (but not the reverb tank) prior to the loop.
    That seems to be the experience of a few different users from what I read online. Some people report improvements by replacing some of the caps.
    edited August 2019
    After watching this vid, I thought I'd try a 12AY7 (45mu) in v4 instead of a 12AX7 (100mu):
    I was sure I had one in my valve draw, turns out I didn't.
    I tried a sovtek 5751 (70mu) and a GE 12AT7 (60mu) but could barely hear the reduction in hiss.
    Next I tried a Bugle Boy 12AU7 (18mu) and it was great! Almost silent running. Amp is not as loud and the gain feels slightly different, but I like it. Still enough volume for my 5 piece band, I'm sure.
    I'm just after reassurance that I'm not causing any harm with this valve substitution? And that I won't be going through a 12AU7 per week!?
    Is it worth sourcing a 12AY7 to see if it's any good?
  • tone1tone1 Frets: 5169
    Every Supersonic 22 I’ve tried has hissed like a bag of angry snakes :s
    1reaction image LOL 0reaction image Wow! 3reaction image Wisdom
    Be careful with the 12AU7 - it will be drawing a lot more current and could overload the plate resistors. Ideally you need to measure the voltage drop across them and calculate the power dissipation.
    In some of their modern amps Fender have used such small resistors that even a 12AY7 can blow them - including the Bassman RI, which is doubly frustrating as the *original* Bassman was intended to use one.
  • RiftAmpsRiftAmps Frets: 3166
    edited August 2019 tFB Trader
    +1 on this. I wouldn't use anything other than an AX7 unless you're absolutely sure the amp can run something else.
    Also, by using a lower gain valve you're not actually fixing the problem, just covering it up with a band aid.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • uncledickuncledick Frets: 406
    Reverb hiss pretty much comes as standard on the SS22.  In concept , it's a fantastic amp but the hiss issues as well as the weird non-linearity and response at low to medium volume levels meant mine had to go.  Crank it up to pub gig volume and it's a cracker.
    Ok fair enough :/
    Any opinions on the other mod in the you tube clip?
    Anyone tried it?
  • stylesforfreestylesforfree Frets: 176
    edited October 2022
    DannyP said:
    Ok fair enough
    Anyone tried it?
    Hey Danny, do you still have your supersonic 22? I got one last month and its also quite noisy, mine is a 2019 model so in theory it should have had all the tech-fixes in place.....alas.
    Hi @stylesforfree, yes I do.
    The V4 valve swap does help, as does a noise gate in the loop, although that does come before the onboard reverb meaning gated reverb. A reverb pedal in the loop after the gate solves this, but that's extra faff/expense etc.
    I tend to use my 5-watter at home and gig/rehearse with the SS22 at volumes where the noise isn't an issue. I'm using it mostly clean with all pedals in the front end nowadays, and it really doesn't bother me that much.
  • @DannyP gotcha, thanks, how much does the 12AU7/12AT7 Lower the reverb level?.
    And what 5 watt amp do you use?
    I just checked and it's a 12AY7 that I have in there at the moment, which apparently is a bit risky, see above. No effect on the reverb I don't think.
    My 5 watt amp is one I made myself from an Ampmaker kit.
  • Like others here, I had one, loved the tones, hated the hiss. Regret selling it. They’re useless for home use if you can’t ignore the hiss. In a band, they’re great. I don’t think you can mod the hiss away.
