Two pedals died on me today... both loopers...
ChéChé Frets: 305
edited July 2019 in FX
No looping fun for me this evening...
My EHX 360 Looper no longer works but presents all sorts of horrible noise if I switch to a higher mA setting on my VLPP2+. The TC Alter Ego X4 doesn't even power up now. I was using both quite recently so not sure what the issues could be....
Any thoughts?
  • PhilMPhilM Frets: 279
    Do you have another power supply you could try?
  • ICBMICBM Frets: 72459
    Ché said:
    Any thoughts?
    Ché said:
    My EHX
    The TC
  • TeetonetalTeetonetal Frets: 7807
    First thought is has the PSU died.
  • danodano Frets: 1594
    In one in the loop of the other ?!
    On a serious note are they same psu?  If the psu "appears" OK still don't plug anything into it, could well be a spike coming out which is damaging pedals.
  • GrangousierGrangousier Frets: 2643
    Is there an infectious disease that kills looper pedals? Perhaps something widespread but benign in delay pedals that's spread along the patch cable and metastasized?
    Could be lupus...
  • KittyfriskKittyfrisk Frets: 18839
    Could be lupus...
    KT Tunstall syndrome?
  • ChéChé Frets: 305
    ICBM said:
    Ché said:
    Any thoughts?
    Ché said:
    My EHX
    The TC
    I gave you a LOL for making me chuckle. Such a smart arse comment were it not for the fact you’re completely right... does that make you more of a smart arse, or make me bitter for buying poor quality pedals..
    Pedals that aren’t even cheap TC electronic! You hear me?!
    I’m gonna end up with a board full of Boss pedals at this rate....
    For everyone enquiring, I tried it with my
    ISO brick and PP2+ to no avail. It had worked with both previously and they both power my other pedals. I’ve just forked out for my Deep
    Impact repairing, I swear the universe doesn’t want me to finish this pedalboard...
  • MajorscaleMajorscale Frets: 1563
    As Dano said earlier, you could have a fault with the psu spiking. Were the three pedals running off the same psu at the time of their individual failures?
  • robertyroberty Frets: 10893
    Are they newish? No harm in contacting support
    Three separate failures, even with two of them being EH and TC, does make me think there may be an outside factor. As Dano and Majorscale said, if they were all on the same power supply at the time that must be the chief suspect.
  • ChéChé Frets: 305
    edited July 2019
    The Deep Impact was a fault with that pedal specifically.
    My bass amp died last night as well, still powers up and receives signal but with no sound from the speaker, I’m guessing it’s blown. I think this is the year everything I own breaks  p
    i didn’t have the pedals on a board so I kept them in a cupboard when not in use, last time they were out they worked fine. One of the outputs doesn’t work on my PP2+ so I’ll get that looked at.
