Feedback
I had the 2i4 for several years when I first started recording, the Scarlett range are solid interfaces, come with some plugin download codes (even a lite version of a DAW) and Focusrite do some form of giveaway, like a discount or lite version of a plugin each month for registered users.
Gearslutz has quite a lot of informative comparison discussions.
https://forum.cockos.com/showthread.php?t=174445
The latency of the 2nd gen Focusrite Scarlett looks pretty good. Do the 3rd gen match or improve on this?
I'm using a Zoom UAC-2 USB3, which has good low latency performance, but it looks like the Focusrite Scarlett is cheaper and seems to be in the same ball park.
Personally I'd avoid anything that can't achieve less that 7ms.
Installed Audacity and it worked straight away!
I'm after another interface, looking at the Audient range. The ID4 might be worth a look at.
I had an Audient Mico a while ago and the mic pre was very nice.
