Good man. It's a very useful thing to have.
Looking forward to your build
You knocked that DIM bulb tester up quick.. you must be keen I think the Weber kit is a good choice cos having the full BOM makes it much less daunting for a first build and you don't get held up by not having the correct small parts...like the correct size nuts for mounting the transformers etc.
It cracks me up that if you remove the transformers from the BOM when ordering it only costs you $30 less..
I must admit that this thread is starting to make me feel 'itchy' for another build myself, perhaps for 6G15 Reverb Tank.
+1 for @MtB and his wiring advice. Make a copy of the circuit diagram and highlight the connections as you wire them. Adopt a "measure twice, cut once" approach for the build.
Let us know when you're kit arrives.... you should document your build on here, if you a brave enough, cos there's lots of good folks on here to help...and keep you safe
