Wanted: black switch tip
JerkMoansJerkMoans Frets: 8814
Hey you crazy cats!
Just taken delivery of this rather jolly B&G Little Sister.  Just find that the amber switch tip spoils the aesthetic and ruins my day.  Anyone got a spare black one in their parts tin?  Far as I can tell it' s just a bog standard switch...
Inactivist Lefty Lawyer
  • PM sent
  • FunkfingersFunkfingers Frets: 14608
    Yup. One SE Asian switch tip design, available in several colours.
    NOTE: American plastics will not fit. Thicker shaft, different thread.
  • JerkMoansJerkMoans Frets: 8814
    Egad! You’re right!
    I tried the tip from my Les Paul.
    Aaaaaand the screw thread on the LP turns out to be quite a bit wider, so it falls off the B&G, and the B&G tip is too narrow for the LP. Who’d a thunk it?
    Tell me your terms, good @Funkfingers and let us transact for one of your finest narrow thread black switch tips.
    If it is okay with you, I shall wait my turn in the queue. lewisanderson was first.
  • LastMantraLastMantra Frets: 3825
    Goes with the chair though.
    Indeed he was, but our efforts foundered on metric/imperial incompatibility :(
    In that case, I shall PM you later today.
    Our gaudy conservatory furniture really ties the room together.
    Dang. I have a selector switch with one of those orangey plastic tips with the flat face around the thread hole.
    My surplus black switch tips are tapered at the hole end, the hole is narrower and the thread pitch is different.
    Forcing one of these tips onto your existing switch will probably strip the plastic away where the switch shaft thread needs to engage, defeating the object of changing the tip.
    Apologies for raising your hopes and wasting your time.
    Thanks for taking the time to check, and no probs, man: shattered hopes and wasted years are the meat and drink of aspiring guitar players :D
  • flyingvflyingv Frets: 555
    edited August 2019
    Got one @JerkMoans - pm me you delivery deets, and I’ll chuck it into an envelope for you.
    https://i.imgur.com/GvM1Tj8.jpg
