Formatting disk drive urgent query
rlwrlw Frets: 4699
I have a new pc with two hard drives.  One is big, one is not.
I’m using zinstall to copy everything to my new pc and the issue of disk size has come up a bit too late.
Can I format both drives and still retain my windows 10 is?
i should know but now have doubts
  • RabsRabs Frets: 2609
    Hmm, it sounds like a partition where they keep the windows files. Most computers come with it built in rather than on a DVD or CD or something.
    If you have Windows 10 on a disk or external hard drive you can install from that and wipe everything. Otherwise you will wipe your windows install files..
    I think.. Its all changed a bit since I last looked at this kind of stuff.
  • Emp_FabEmp_Fab Frets: 24327
    Windows key, type DISKPART then when you get the "DISKPART>" prompt, type LIST, then post the results here.
    That said, I'm 99% sure that one of your disks will contain your Windows installation and formatting both will trash it.  Sounds like you have a SSD for the Windows files (the smaller disk) and a regular HDD for storage.
  • Danny1969Danny1969 Frets: 10413
    I'm guessing the new PC has a smallish SSD for the OS and a large mechanical drive for data. Zinstall want's to transfer your old c: disk image to the new C: drive but new one is too small
    Formatting won't make the disk any bigger ..... better off starting again OS load wise
  • rlwrlw Frets: 4699
    I needed to format the drive as it was half full and unresponsive.  I cannot see the other drive which is very annoying.
    I do have an sad and a mechanical drive but cannot see the latter , nor could I choose to make zinstall copy to that drive, so I’m not confine it really is there.
