Printable String Spacing guide for nut slotting - anyone have one
redrighthandredrighthand Frets: 746
edited August 2019 in Making & Modding
I'm about to start cutting a new nut. Does anyone have a reliable printable string spacing guide?  I've found this one online, but when I check it by comparing it to a pre slotted nut it doesn't seem to line up - making me wary of using it.
http://www.pitbullguitars.com/wp-content/uploads/2014/01/a347f-NUT-LAYOUT-V2.jpg
  • CorvusCorvus Frets: 2926
    I use that one though from a PDF that was posted on TDPRI. I see that's a Pitbull img, don't know if they nicked it or it the TDRI guy is part of them. Used it lots, works well for me. Pre-slotted nuts can be hit & miss, I have binned ones before with off spacing. Also there are different spacing methods, like even-spaces centre lines vs even gaps.
    Also if you have an existing nut with good spacing you can clamp that with a blank and use it to slot the blank to copy it's spacing.
  • DanielsguitarsDanielsguitars Frets: 3297
    i recently bought a string spacing rule and it's just bloody fantastic, should've bought one along time ago and saves lots of pissing about with calipers etc and strained eyes
    Just sayin
    www.danielsguitars.co.uk
    (formerly customkits)
    I made mini slotted rules from the printout from ally plate, cost nowt. The SM thing is an easy solution sure if you do a lot, not so cheap for occasional use at like 20 squid plus same again for post.
  • SteveRobinsonSteveRobinson Frets: 7039
    I generally use the StewMac ruler but find it's no good for narrow nuts.
    For those I use the calculator on my website, transfer the measurements to Inkscape and print onto a sticky label.
    I stick the label to the nut and cut through the lines using a razor saw to make the starting slots.
    If this is any use to you, you are welcome to it
    https://i.imgur.com/jVnSX3m.jpg
    https://i.imgur.com/bl3QqTO.jpg
  • Thanks all. In the end I used the strings on a guitar with an already well cut nut as a guide, marked and cut very slowly. Worked a treat.
