Battery Powered Amp
BarnezyBarnezy Frets: 2177
So I just sold my THR10C on here and immediately regretted it. I wasn't using it a ton, but then when it was gone I realised I needed to have such an amp regardless. I wasnt overly impressed with the 10C, but it was good for what it is.
I ordered the THR5 as I didn't use any of the 10's additional features. It sounds terrible. So bright and ice picky. I can't get a warm tone from it. If I turn the tone down on both the amp and guitar, it takes the piercing highs off, but then it become dull.
Am I doing something wrong?
Thinking about sending it back. What alternatives are there? Has anyone got the Katana mini?
  • ICBMICBM Frets: 72344
    Vox Mini5 Rhythm.
    The best-sounding battery amp I've ever heard.
  • ecc83ecc83 Frets: 1633
    There's a guy plays in our town centre with a Vox Cube and he is TOO 'KING LOUD!  Pretty clean mind.
    Dave.
  • BluesLoverBluesLover Frets: 665
    The Katana mini is a bit rubbish. Don't believe the hype, it is overpriced, and sounds like a cheap transistor radio. The 4 inch speaker is just too small. Local buskers all seem to use Roland micro cubes. I don't know if they are still good or if there is anything better available now.
  • BarnezyBarnezy Frets: 2177
    I've worked out if I drop the guitar volume two notches it removes the ear piercing highs. Might give it a bit more time.
  • darthed1981darthed1981 Frets: 11755
    Vox Handbag is pretty good.
  • TADodgerTADodger Frets: 211
    Laney mini ST is an option.
  • notanonnotanon Frets: 607
    ICBM said:
    Vox Mini5 Rhythm.
    I have my Vox 5 mini up for sale
    https://www.thefretboard.co.uk/discussion/106988/fs-vox-mini-5-70#latest
    Agree about the tones but lack of connectivity options.
  • FuengiFuengi Frets: 2850
    Pignose?
  • SamgbSamgb Frets: 774
    Blackstar Fly with the extension cab. I've seen some people on here badmouth it but i disagree. its great for a coffee table noodle.
  • p90foolp90fool Frets: 31590
    Fuengi said:
    Pignose?
    This! I should've bought one years before I actually did.
    It won't do anything you expect from a fully featured normal amp, and especially not anything a modeller can do, but it has a very musical feel and sits perfectly in a mix while you're working out what to play.
    When you plug into a Pignose your guitar is purely a musical instrument, not a wired controller for a sound module.
    p90fool said:
    Fuengi said:
    Pignose?
    That’s all entirely true.
    But I’ve just sold mine - which was the fourth or fifth I’ve owned - because I just don’t like the sound of them and it doesn’t work for what I play. (Even with a buffered pedal in front, which does improve them.)
    A bit of trivia - although not exact, the circuit is very closely related to the Brian May ‘Deacy’ amp that John Deacon made from a scrap radio amplifier. They’re both a derivative of one of the first discrete-transistor audio amp circuits.
